How to control Servo using Adafruit 16 channel servo control
Re: How to control Servo using Adafruit 16 channel servo con
by dastels on Mon Aug 02, 2021 8:24 pm
Back to Carter's question... what version of python is python?
What happens if you use
python3 prog.py
dastels
by syedmfaheem on Mon Aug 02, 2021 8:59 pm
dastels wrote:Back to Carter's question... what version of python is python?
python3 prog.py
Please find attached screenshot. I executed two commands in screen shot.
1- python --version
2-python3 prog.py
syedmfaheem
by dastels on Mon Aug 02, 2021 10:42 pm
Apologies, I glossed over where you mentioned the Python version.
dastels
by dastels on Mon Aug 02, 2021 10:44 pm
Is i2cdetect is reporting devices at addresses 40 and 70?
dastels
by syedmfaheem on Mon Aug 02, 2021 10:50 pm
dastels wrote:Is i2cdetect is reporting devices at addresses 40 and 70?
syedmfaheem
by dastels on Tue Aug 03, 2021 9:53 am
Well, that's why it's failing. Have you tried shutting down the Pi and bringing it back up?
dastels
by syedmfaheem on Tue Aug 03, 2021 10:31 am
dastels wrote:Well, that's why it's failing. Have you tried shutting down the Pi and bringing it back up?
I rebooted but still same out put. Then I re-verify my previous steps.
1- Executed command sudo apt-get install python-smbus
2- Executed command sudo apt-get install i2c-tools
3- I followed https://learn.adafruit.com/adafruits-ra ... guring-i2c
4- Executed command reboot
Please find attached screen shots. Please advice.
syedmfaheem
by adafruit_support_carter on Tue Aug 03, 2021 10:43 am
You'll need to solder on the 2x20 socket header to the Servo HAT.
by syedmfaheem on Tue Aug 03, 2021 10:46 am
adafruit_support_carter wrote:You'll need to solder on the 2x20 socket header to the Servo HAT.
I did't understand.
Did you mean 40-Pin Pi GPIO Stacking Header all 40 pins point need to solder?
Please advice.
syedmfaheem
by adafruit_support_carter on Tue Aug 03, 2021 11:06 am
The part shown here needs to be soldered in place on the HAT. Same would be true for any header option used, like stacking.
Just to be sure what you're trying to do - are you wanting to add stacking headers? Similar to the option discussed here?
https://learn.adafruit.com/adafruit-16- ... cking-hats
Also note that the servo header pins also need to be soldered on. The ones you actually plug the servo into.
by dastels on Tue Aug 03, 2021 12:16 pm
Good catch.
Yes, syedmfaheem, headers always need to be soldered. It is really the only way to get a reliable electrical connection, which is especially important for communication signals like I2C, SPI, and even UART. It also provides a string mechanical connection.
Soldering well is probably the most useful skill you can learn if you want to work with electronics.
For more information/tips on soldering see https://learn.adafruit.com/adafruit-guide-excellent-soldering and https://learn.adafruit.com/collins-lab-soldering.
dastels
by syedmfaheem on Tue Aug 03, 2021 12:20 pm
adafruit_support_carter wrote:The part shown here needs to be soldered in place on the HAT. Same would be true for any header option used, like stacking.
The attachment header.jpg is no longer available
Thank you. After solder showing input in 40 and 70 , program start working and servo start moving.
Thank you very much for your time and efforts.
syedmfaheem
by adafruit_support_carter on Tue Aug 03, 2021 1:10 pm
Woot! Cool. Glad it was something simple. Good job getting it soldered! Hope your project goes well. Have fun!
