I can't get a simple button to work
by bgambrell on Tue Sep 14, 2021 12:31 pm
I am apparently very bad at this.
I have a button, which is essentially a switch, and I've got it set up as a pull-down. I have some simple arduino code that reads the corresponding pin and if it is HIGH, it turns on the LED_BUILTIN.
I press the button. Nothing happens.
int btn11Pin = 11;
int btn11State = 0;
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(btn11Pin, INPUT);
  btn11State = digitalRead(btn11Pin);
  if (btn11State == HIGH) {
    digitalWrite(LED_BUILTIN, HIGH);
  } else {
    digitalWrite(LED_BUILTIN, LOW);
I'm doing this on a Feather Bluefruit LE 32u4
bgambrell
Re: I can't get a simple button to work
by adafruit_support_bill on Tue Sep 14, 2021 12:34 pm
If you post a photo of your circuit we can try to spot the problem.
by bgambrell on Tue Sep 14, 2021 1:01 pm
edited
bgambrell
by adafruit_support_bill on Tue Sep 14, 2021 1:04 pm
Try turning your button 90 degrees. The two pins you are connected to may be connected together internally.
by bgambrell on Tue Sep 14, 2021 1:06 pm
Not the issue. I can wire the pin directly to the logic power and it still does nothing.
Is there a different way to reference the pins?
bgambrell
by adafruit_support_bill on Tue Sep 14, 2021 3:05 pm
What do you have connected to pin 13?
by bgambrell on Tue Sep 14, 2021 5:15 pm
It was grounded but I removed it from ground and now the button is sort of working. The LED is very dim when I press the button. Not as bright as it should be.
bgambrell
by bgambrell on Tue Sep 14, 2021 5:17 pm
I decided off-hand to re-upload my sketch. And now it works! I am happy because it works. I am sad because I do not understand what was happening.
bgambrell
by adafruit_support_bill on Tue Sep 14, 2021 6:43 pm
Pin 13 drives the on-board LED. With it shorted to ground, it cannot not go HIGH to turn on the on-board LED. (That is also a good way to burn-out the output drivers for the pin.)
by bgambrell on Thu Sep 16, 2021 10:51 am
Thank you!
bgambrell
