Peristaltic pump in reverse
by lame_sauce on Fri Sep 17, 2021 3:14 pm
Hi All,
I'm working on a project and could use some help. I was wondering how I could run a peristaltic pump in reverse using circuit python. I have the pump turning on through a non latching relay attached to a FunHouse (code below). Any tips would be great!
import board
import time
import digitalio
water_pump = digitalio.DigitalInOut(board.A2)
water_pump.direction = digitalio.Direction.OUTPUT
water_pump.value = True
time.sleep(5)
water_pump.value = False
lame_sauce
Re: Peristaltic pump in reverse
by adafruit_support_bill on Fri Sep 17, 2021 4:09 pm
You can't do it with a single relay. To reverse a motor you need an 'H-Bridge' like the one on a TB6612B: https://learn.adafruit.com/adafruit-tb6 ... r-breakout
by lame_sauce on Fri Sep 17, 2021 6:19 pm
adafruit_support_bill wrote:You can't do it with a relay. To reverse a motor you need an 'H-Bridge' like the one on a TB6612B: https://learn.adafruit.com/adafruit-tb6 ... r-breakout
Oh thank you I'll check this out!
lame_sauce
by adafruit_support_bill on Sat Sep 18, 2021 5:40 am
Also check the current requirements of your motor. If it pulls more than 1.2A, you will need something with more current capacity like the DRV8871: https://www.adafruit.com/product/3190
by jps2000 on Sat Sep 18, 2021 10:02 am
Of course you can use 2 relays wired like a h bridge
( single pole double throw relay contact)
jps2000
