BME680 Breakout Not Working
by TMAR2016 on Tue Dec 10, 2019 3:44 pm
The BME680 Breakout is my first sensor ever. I am trying to use it with a arduino uno. I downloaded the supporting libraries in the arduinio IDE and wired it in a IC2 configuration (0x76). When I run the example code the serial monitor will print "BME680 Test" but will not take any measurements. I have run the code without wires connected and I get the expected "Could not find a valid BME680 sensor, check wiring!" error message. Is there a step I missed? How can I get the sensor to take measurements and print on the serial monitor?
Thank you!
TMAR2016
Re: BME680 Breakout Not Working
by dastels on Tue Dec 10, 2019 6:00 pm
Do you see "Failed to perform reading :(" repeatedly?
dastels
by TMAR2016 on Tue Dec 10, 2019 6:13 pm
This is the code I am using: (I modified it with print statements as an attempt to debug it)
Serial.begin(115200);
while (!Serial);
Serial.println(F("BME680 test"));
Serial.println("I am going into the if statement");
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
Serial.println("I am here");
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
Serial.println("I am initialized");
if (! bme.performReading()) {
Serial.println("Failed to perform reading :(");
return;
Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
Serial.println();
delay(2000);
When I run this code my serial monitor outputs:
If I comment out the if statement in the setup, I get the error you describe (i.e. Failed to perform reading continuously repeating).
Has this happened to you?
TMAR2016
by TMAR2016 on Tue Dec 10, 2019 6:18 pm
Update: The problem appears to be my (!bme.begin()) command. It will not make it past this line of code... Is this a library problem?
TMAR2016
by dastels on Tue Dec 10, 2019 6:45 pm
You said you've connected the breakout's SDO to ground to have it at address 0x76? Why? Do you have another I2C device at 0x77?
dastels
by TMAR2016 on Tue Dec 10, 2019 7:05 pm
I don't have any other sensor attached to my Uno. I am operating at (0x76) because I found a comment on another website that said this could be my problem. If I remove the SDO ground cable (returning the device to (0x77)) I have the same problem. I tried using an I2C scanner, but I couldn't even get that sketch to detect my device...
TMAR2016
by akmishra_99 on Sat Sep 18, 2021 11:59 am
I bought two BME680 breakout board from Adafruit, one of them works and other one does not work, it keeps telling me that no valid BME680 found("Could not find a valid BME680 sensor, check wiring!") , can I get replacement for not working BME680 breakout
-Thanks
-Alok
akmishra_99
