Sound board with LOTS of triggers?
Re: Sound board with LOTS of triggers?
by maybedave on Sat Sep 18, 2021 4:25 pm
Hi Mikey! This project has come a long way, thanks to your help!
I'm getting close to mounting the parts into [url]this thing[/url]https://www.amazon.com/gp/product/B005P1S7NQ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 and wondered if you had any tips. Can I just hot glue the audio FX sound boards to the case inside? What about the LiPo battery? Do I have to worry about heat management at all?
Thank you so much! Will definitely post the finished product.
maybedave
by mikeysklar on Sun Sep 19, 2021 10:38 am
Those buttons look great. This is really coming along nicely.
What material is the enclosure you will be mounting the board to? If it is wood or plastic I would try and use small mounting bolts or screws for the 100 mill wide holes. If your surface is metallic then it would be a good idea to use standsoffs. The Black Nylon Machine Screws and standoff set is a goto for many of my projects.
https://www.adafruit.com/product/3299
mikeysklar
by TacoBill65 on Sun Oct 24, 2021 11:50 am
I finally got around to attempting to add files to my project.
I have 2 cd's with well over 4000 sound bites.
I was under the impression once you connect the micro usb and to any computer it would show up as a thumb drive.
I have tried 5 computers winxp,win7Pro,win10,win11 and MacOs. none of them see the device as a thumb drive so I guess I am unable to upload files.
any help would be great, email, phone or here
thanks
curds@me.com
270-320-9805
TacoBill65
by TacoBill65 on Sun Oct 24, 2021 11:57 am
I just used a single pole 11 position switch and a single push button just as easy as all the momentary buttons. but i like the pcb for sure.
I use www.easyeda.com......
imruffsdad wrote:Hey Maybedave, I just finished a prototype of something similar to this a week or so ago. I have a 16 button matrix in which each button plays a different sound effect. This uses a Feather M4 Express and the MusicMaker Feather Wing that stores the files and plays them. I have it on a protoboard but the two Feather products could easily stack and take up very little space. Just FYI if you're interested. I can post better pictures and the code if you want. The caveat is that the MusicMaker only works, as far as I know, on an Arduino platfrom.
All the best, Dennis
TacoBill65
