Time Tracking Cube Code Question
by hepaestus on Tue Sep 28, 2021 11:43 am
Hello!,
On the code page for the https://learn.adafruit.com/time-tracking-cube/code there is reference to this code:
  // Send to Adafruit IO based off of the orientation of the cube
  switch (cubeState)
  case 1:
    Serial.println("Switching to Task 1");
    // update the neopixel strip
    updatePixels(50, 0, 0);
    // play a sound
    tone(PIEZO_PIN, 650, 300);
    Serial.print("Sending to Adafruit IO -> ");
    Serial.println(taskTwo);
    cubetask->save(taskTwo, minutes); // THIS IS MY QUESTION MY Minutes are not being saved.
    // There is no mention of this method signature in the docs
    // https://adafruit.github.io/Adafruit_IO_Arduino/html/class_adafruit_i_o___feed.html#a783174b3bb1fc40a2e89c78cc6e6e5c1
    // I do not think this minutes data is being sent to AIO.
    // reset the timer
    minutes = 0;
    break;
THIS IS MY ISSUE.
https://adafruit.github.io/Adafruit_IO_ ... 8cc6e6e5c1
What am I missing?
Thank You,
Pete
hepaestus
Re: Time Tracking Cube Code Question
by brubell on Wed Sep 29, 2021 11:44 am
`save()` publishes data to Adafruit IO, see: https://github.com/adafruit/Adafruit_IO ... ub.ino#L85
When you open http://io.adafruit.com/monitor, do you see any data coming into the minutes feed?
brubell
by hepaestus on Wed Sep 29, 2021 11:59 am
Yes I get the STRING data. See the attached image of the AD.io page.
I am not getting the second piece of the data, the minutes passed.
Thanks,
Pete.
hepaestus
by brubell on Mon Oct 04, 2021 10:13 am
What does your taskTwo feed look like?
brubell
by hepaestus on Mon Oct 04, 2021 10:20 am
I only have one feed for this.
hepaestus
by hepaestus on Mon Oct 04, 2021 2:39 pm
I am trying to measure the tilt angle of the project but the sensor values change wildly:
I am not even moving the sensor and you can see below it has values all over the place.
// Basic demo for accelerometer readings from Adafruit LIS3DH
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// Used for software SPI
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
// Used for hardware & software SPI
#define LIS3DH_CS 10
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
void setup(void) {
  Serial.begin(115200);
  while (!Serial) delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("LIS3DH test!");
  if (! lis.begin(0x18)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldnt start");
    while (1) yield();
  Serial.println("LIS3DH found!");
  lis.setRange(LIS3DH_RANGE_2_G);   // 2, 4, 8 or 16 G!
  Serial.print("Range = "); Serial.print(2 << lis.getRange());
  Serial.println("G");
  lis.setDataRate(LIS3DH_DATARATE_10_HZ);
  Serial.print("Data rate set to: ");
  switch (lis.getDataRate()) {
    case LIS3DH_DATARATE_1_HZ: Serial.println("1 Hz"); break;
    case LIS3DH_DATARATE_10_HZ: Serial.println("10 Hz"); break;
    case LIS3DH_DATARATE_25_HZ: Serial.println("25 Hz"); break;
    case LIS3DH_DATARATE_50_HZ: Serial.println("50 Hz"); break;
    case LIS3DH_DATARATE_100_HZ: Serial.println("100 Hz"); break;
    case LIS3DH_DATARATE_200_HZ: Serial.println("200 Hz"); break;
    case LIS3DH_DATARATE_400_HZ: Serial.println("400 Hz"); break;
    case LIS3DH_DATARATE_POWERDOWN: Serial.println("Powered Down"); break;
    case LIS3DH_DATARATE_LOWPOWER_5KHZ: Serial.println("5 Khz Low Power"); break;
    case LIS3DH_DATARATE_LOWPOWER_1K6HZ: Serial.println("16 Khz Low Power"); break;
int x, y, z;                        //three axis acceleration data
double roll = 0.00, pitch = 0.00;       //Roll & Pitch are the angles which rotate by the axis X and y
void RP_calculate(){
  double x_Buff = float(x);
  double y_Buff = float(y);
  double z_Buff = float(z);
  //roll = atan2(y_Buff , z_Buff) * 57.3;
  roll =  atan2( y_Buff , x_Buff ) * 57.3;
  pitch = atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3;
  sensors_event_t event;
  lis.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("2X: "); Serial.print(event.acceleration.x);
  Serial.print(" \t2Y: "); Serial.print(event.acceleration.y);
  Serial.print(" \t2Z: "); Serial.print(event.acceleration.z);
  x = event.acceleration.x;
  y = event.acceleration.y;
  z = event.acceleration.z;
  RP_calculate();
  Serial.print("\tRoll 2: "); Serial.print(roll);
  Serial.print("\tPitch 2: "); Serial.print(pitch);
  Serial.println();
  delay(200);
Here is the OUTPUT:
14:36:20.148 -> 2X: 182.62    2Y: 90.39    2Z: 60.28   Roll 2: 26.31   Pitch 2: -59.28
14:36:20.352 -> 2X: 212.75    2Y: 90.39    2Z: 30.16   Roll 2: 23.00   Pitch 2: -65.90
14:36:20.558 -> 2X: -239.14    2Y: 180.76    2Z: 30.16   Roll 2: 143.03   Pitch 2: 52.64
14:36:20.758 -> 2X: 212.75    2Y: 150.64    2Z: 60.28   Roll 2: 35.28   Pitch 2: -52.69
14:36:20.964 -> 2X: 182.62    2Y: 120.51    2Z: 120.53   Roll 2: 33.40   Pitch 2: -47.01
14:36:21.170 -> 2X: 152.50    2Y: 90.39    2Z: 90.41   Roll 2: 30.63   Pitch 2: -50.06
14:36:21.376 -> 2X: 212.75    2Y: 150.64    2Z: 90.41   Roll 2: 35.28   Pitch 2: -50.48
14:36:21.580 -> 2X: -239.14    2Y: 120.51    2Z: 90.41   Roll 2: 153.35   Pitch 2: 57.89
14:36:21.783 -> 2X: -239.14    2Y: 30.13    2Z: 90.41   Roll 2: 172.86   Pitch 2: 68.35
14:36:21.990 -> 2X: 212.75    2Y: 60.26    2Z: 120.53   Roll 2: 15.80   Pitch 2: -57.68
14:36:22.162 -> 2X: -239.14    2Y: 150.64    2Z: 60.28   Roll 2: 147.90   Pitch 2: 55.95
hepaestus
