Help with Microlipo charger
by KenFellows on Tue Oct 19, 2021 9:42 pm
I ordered two Microlipo 3.7v/4.2v lipoly/lilon battery chargers. I shorted the back jumper per instructions. Both of my chargers started to smoke once I plugged them into the PC's USB port. Now both the red and green lights are on all the time. It does not appear that they are charging the battery. I was going to use the MicrolipoI with the PL 603030 3.7v 500mAh battery that I ordered. Is there a better charger to use with the battery I ordered? I am going to use the battery to power the Circuit Playground Classic board.
KenFellows
Re: Help with Microlipo charger
by adafruit_support_mike on Tue Oct 19, 2021 9:57 pm
Post photos of the MicroLiPo boards and the LiPos you had connected to them please. We need to see the LiPos and their connections, but don't actually plug the LiPos into the boards.. there's no point in risking more damage.
800x600 images usually work best.
by KenFellows on Wed Oct 20, 2021 10:00 am
Will send the photos later today.
KenFellows
by KenFellows on Wed Oct 20, 2021 3:51 pm
Attached are two file that show the chargers.
IMG_20211020_154412_MP (2).jpg (204.44 KiB) Viewed 99 times
IMG_20211020_154430_MP (2).jpg (215.87 KiB) Viewed 99 times
KenFellows
by adafruit_support_mike on Wed Oct 20, 2021 5:48 pm
Please post photos of the LiPos and their connectors as well.
by KenFellows on Thu Oct 21, 2021 6:40 pm
I hope can see from these images what you are looking for.
IMG_20211021_183324_MP (2).jpg (189.48 KiB) Viewed 86 times
KenFellows
by KenFellows on Fri Oct 22, 2021 6:19 pm
Have you seen my reply? I need a charger for the battery.
KenFellows
by adafruit_support_mike on Sun Nov 14, 2021 7:53 pm
It looks like that LiPo's positive and negative wires go into the JST-PH2 header with the opposite polarity of ours:
https://www.adafruit.com/product/1578
There are no official standards for connector polarity, and you can find both versions online.
It isn't hard to fix though: the plastic JST-PH2 plug has a couple of tabs on the bottom that hold the wire terminals in place. You can lift those with a small screwdriver, pull the terminals out, then replace the terminals so they match our chargers and boards.
