It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
Defective Pi zero W
Defective Pi zero W
by bollarampavan on Tue Oct 26, 2021 2:32 am
I have ordered Rasberry pi zero W (order number 2688797-3058429134) and it is not turning ON.
I don't see any green light or blinking light. Of course, did connect to a power source and also an SD card with a PI image. I have verified my SD content by inserting it into another pi zero and I see the green light there. So I came to the conclusion that the pi zero that I have ordered from you is defective. Please help.
bollarampavan
Re: Defective Pi zero W
by adafruit_support_carter on Thu Oct 28, 2021 2:31 pm
Try this test and see what happens:
https://learn.adafruit.com/raspberry-pi ... -zero-dead
What operating system image are you using and how did you image it to the SD card?
by bollarampavan on Thu Oct 28, 2021 5:20 pm
Unfortunately, the device is not detected when connected with a USB. I am using Mac and have run this command to detect devices
ioreg -p IOUSB -w0 | sed 's/[^o]*o //; s/@.*$//' | grep -v '^Root.*'
LIst of devices that i did see are:
AppleUSBVHCIBCE Root Hub Simulation
Apple T2 Controller
Touch Bar Backlight
Touch Bar Display
FaceTime HD Camera (Built-in)
Ambient Light Sensor
Headset
Apple Internal Keyboard / Trackpad
AppleUSBXHCI Root Hub Simulation
USB3.1 Hub
USB2.0 Hub
USB-C Digital AV Multiport Adapte
I have used Rasberry Pi imager to image my SD card.
The OS I have tried to load is Raspberry Pi OS(32-bit).
I have also run another test by connecting my new PI(The Device which I have reported) and also my old pi zero to monitor with an HDMI cable. my old is running just fine, so I don't see any problem with the image that is loaded to the SD card.
bollarampavan
by bollarampavan on Tue Nov 02, 2021 2:12 pm
Guess what, I am right about my debugging and I just received another pi zero(2695842-0681430691
) from Adafruit and it is working perfectly fine. so Pi zero that I purchased earlier is indeed defective. Please help me with the return order.
bollarampavan
by adafruit_support_carter on Tue Nov 02, 2021 2:27 pm
OK, lets' replace it.
Send an email to support@adafruit.com with a link to this thread and the order number above and they can send you a replacement Pi Zero W.
