ssd1306 display
ssd1306 display
by gadjet on Wed Oct 27, 2021 3:35 pm
HI,
I have an Arduino running an SSD 128x64 OLED display, the display writes Temp and Humidity values to the screen every 10 seconds or so and everything works fine with the display.setTextSize(2) but if I change the code to display.setTextSize(3) then it works for 2 or 3 updates then just stops, Im sure the Arduino crashes as well because I pulse an LED when the screen updates but the LED stops pulsing as well.
Also the values on the OLED display get slightly corruptes on the last update.
Any thoughts? could it be a bug?
gadjet
Re: ssd1306 display
by adafruit_support_bill on Thu Oct 28, 2021 5:12 am
What kind of Arduino are you using? Also, please post your code.
Re: ssd1306 display
by gadjet on Thu Oct 28, 2021 10:12 am
It's a custom PCB using an ATMEGA 328P-PU.
The main bit of code is below, in the setup if the setTextSize(2) is changed to setTextSize(3) it crashes after a few updates, left at 2 it runs day and night without issue.
  pinMode(LED_BUILTIN, OUTPUT);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  aht.begin();
  display.clearDisplay();
  display.display();
  display.setTextSize(2);             // Draw 2X-scale text
  display.setTextColor(SSD1306_WHITE, SSD1306_BLACK);
  // Clear the buffer
  sensors_event_t humidity, temp;
  aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
  display.setCursor(0, 15);
  display.print(temp.temperature);
  display.println(" C");
  display.setCursor(0, 40);
  display.print(humidity.relative_humidity);
  display.print(" %rH");
  //display.print(F("0x")); display.println(0xDEADBEEF, HEX);
  display.display();
  //pulseLED();
  delay(20000);
2021-10-28 12.13.52-1small.jpg (558.72 KiB) Viewed 69 times
gadjet
Re: ssd1306 display
by adafruit_support_bill on Thu Oct 28, 2021 11:32 am
Most likely a memory issue. The 328 has only 2K of SRAM and the 128x64 display takes up half of that just for the frame buffer.
This guide has some tips for diagnosing memory problems and optimizing memory usage: https://learn.adafruit.com/memories-of- ... ot-dot-dot
Re: ssd1306 display
by gadjet on Thu Oct 28, 2021 12:41 pm
Thanks I'll have a read
gadjet
