Help with MPL3115A2 and Raspberry Pi Pico
by antoniopared on Tue Oct 26, 2021 1:43 pm
this is my first project with microcontrollers, and i'd like to ask for help in figuring out what i am doing wrong. i connected an MPL3115A2 to a Raspberry Pi Pico running CircuitPython 7.
here is my code:
import board
import adafruit_mpl3115a2
import busio
import time
scldata = board.GP7
sdadata = board.GP6
i2c = busio.I2C(scldata, sdadata)
sensor = adafruit_mpl3115a2.MPL3115A2(i2c)
and here is the output:
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
  File "code.py", line 11, in <module>
  File "/lib/adafruit_mpl3115a2.py", line 149, in __init__
  File "/lib/adafruit_mpl3115a2.py", line 194, in _poll_reg1
  File "/lib/adafruit_mpl3115a2.py", line 171, in _read_u8
  File "/lib/adafruit_mpl3115a2.py", line 167, in _read_into
OSError: [Errno 116] ETIMEDOUT
Code done running.
Press any key to enter the REPL. Use CTRL-D to reload.
am i missing something? thanks!
antoniopared
Re: Help with MPL3115A2 and Raspberry Pi Pico
by adafruit_support_carter on Thu Oct 28, 2021 11:42 am
Code looks OK. It may be something hardware related. Please post a photo of your setup showing how everything is connected.
by antoniopared on Thu Oct 28, 2021 1:03 pm
hello, thank you for the reply. please see below photo and let me know if i need to post a different angle. thank you!
antoniopared
by adafruit_support_carter on Thu Oct 28, 2021 1:20 pm
Thanks. That looks generally OK. Does it show up OK in an I2C scan?
https://learn.adafruit.com/scanning-i2c ... cuitpython
You'll want to continue to setup your I2C bus same as you have been (the guide is generic). So keep this past as is:
scldata = board.GP7
sdadata = board.GP6
by antoniopared on Fri Oct 29, 2021 8:45 am
here is my code now,
import busio
import board
import time
scldata = board.GP7
sdadata = board.GP6
while not i2c.try_lock():
    pass
try:
    while True:
        print("I2C addresses found:", [hex(device_address)
              for device_address in i2c.scan()])
        time.sleep(2)
finally:  # unlock the i2c bus when ctrl-c'ing out of the loop
    i2c.unlock()
and it outputs this messge:
code.py output:
I2C addresses found: ['0x60']
  File "code.py", line 19, in <module>
KeyboardInterrupt:
Code done running.
but if i add these two lines at the end:
    print (sensor)
the same error will occur:
  File "code.py", line 28, in <module>
should i try adding a 10k resistor on both the SDA and SCL lines?
antoniopared
by adafruit_support_carter on Fri Oct 29, 2021 10:30 am
OK, set this up and was able to recreate this issue right away. Seeing all same behavior you are - I2C scan works, but get ETIMEDOUT. Not sure what is happening. Opened a new issue for this here:
https://github.com/adafruit/Adafruit_Ci ... /issues/19
by antoniopared on Fri Oct 29, 2021 11:40 am
wow thank you so much for looking and ooening the github issue! i will keep an eye on it as well... :-)
antoniopared
