Adafruit Looper won't let me exit program - Rasp Pi 4
by Galmo1 on Tue Nov 09, 2021 9:34 pm
So I installed the Adafruit video looper on my Raspberry Pi 4 model B using these steps from a Youtube video: "Make a USB Video Looper with a Raspberry Pi 4 Model B - YouTube
Video Looper with Raspberry Pi 4 Model B - Tutorial Australia".
It worked great at first. Would plug in the USB, it played the videos, then when I wanted to exit the program I would hit ESC and get back to the main screen.
Now when I hit ESC, nothing happens. It remains on the black screen that says 'Hit ESC to exit'. The program still runs videos when I plug in the USB.
Luckily (I hope), the command screen still is accessible. I've tried a bunch of commands to kill the specific program but it still leaves me with the 'Hit ESC to exit' screen. If someone has any other options to try and help exit this program, please share! Thanks!
Galmo1
Re: Adafruit Looper won't let me exit program - Rasp Pi 4
by mikeysklar on Fri Nov 12, 2021 3:29 pm
If you remotely login are you able to stop | start | restart the looper:
sudo supervisorctl stop video_looper
sudo supervisorctl start video_looper
sudo supervisorctl restart video_looper
mikeysklar
by Galmo1 on Thu Nov 18, 2021 8:57 pm
So it worked at first, but now I'm constantly stuck in the command prompt screen.
I tried $ sudo reboot, but it still starts up the video_looper program and will not let me ESC. Now somehow my videos don't even play. I see a cursor in the middle of the screen where I can type in the prompt. The program says it detects a video, but after the countdown ends it goes right to showing that cursor.
I typed in $ sudo exit, and that only brought me to a black screen where I can type anything, but no commands worked anymore. I was forced to then use CTRL+ALT+DEL to reboot.
Do you think this error can be from the coding in the video looper program?
Galmo1
by mikeysklar on Fri Nov 19, 2021 2:20 pm
If you can remotely login (via ssh) you can shutoff the program via command line.
There are log files for what the looper is doing in /var/log/supervisor/*
There is another thread on video looper in our forums that sounds familiar to yours. The videos were sometimes being mounted from a different location. Instead of /media/pi instead of /mnt/usbdrive0. There user also created a script to enable / disable the looper.
viewtopic.php?f=8&t=138174&p=683592&hilit=supervisorctl#p683592
#!/bin/sh
# Make sure script is run as root.
if [ "$(id -u)" != "0" ]; then
echo "Must be run as root with sudo! Try: sudo ./disable.sh"
exit 1
fi
# !!!Make sure that enable.sh has permission: sudo chmod +x enable.sh !!!!
# Enable supervisor process that start video looper.
rm /etc/supervisor/conf.d/video_looper.conf.disabled
cp /home/pi/pi_video_looper/video_looper.conf /etc/supervisor/conf.d/video_looper.conf
mikeysklar
by Galmo1 on Sat Nov 20, 2021 2:24 pm
mikeysklar wrote:If you can remotely login (via ssh) you can shutoff the program via command line.
I tried this, and it left me with a blank screen where I can only run commands.
mikeysklar wrote:There are log files for what the looper is doing in /var/log/supervisor/*
[code]#!/bin/sh
Erik stated "The problem is while booting sometimes the usb-stick with videofiles was automounted on /media/pi/ so it was not mounted on /mnt/usbdrive0/.
So i unchecked the first two lines in preferences regarding the automount possibility in Volume Management in the File Manager tree."
How do I uncheck those first two lines in preferences? I don't know how to even get to 'preferences'.
Thanks for helping!
Galmo1
by mikeysklar on Sun Nov 21, 2021 2:56 pm
I think Erik's mention of disabling the first time lines in the Volume Management Tree is related to being in GUI mode (X-Windows) and running. You probably could enter this with the startx command.
 Start file manager (pcmanfm) and go to Edit / Preferences / tab Volume Management and disable automount options..
Now I think the above is only relevant if you are running in GUI mode which I do not believe you are doing so this is turning into a tangent that is getting us off course.
I would focus on making sure your mounted filesystem is what you expect to see. When you running the follow command what is the output?
df -H
mount
mikeysklar
by Galmo1 on Sat Nov 27, 2021 3:10 pm
Thank you for being patient with me! Lol
When I run "df -H" I got the following:
Filesystem Size Used Avail Use% Mounted on
/dev/root 32G 3.4G 27G 12% /
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 2.1G 0 2.1G 0% /dev/shm
tmpfs 2.1G 9.0M 2.0G 1% /run
tmpfs 5.3M 4.1k 5.3M 1% /run/lock
tmpfs 2.1G 0 2.1G 0% /sys/fs/cgroup
/dev/mmcblk0p1 265M 50M 215M 19% /boot
tmpfs 402M 4.1k 402M 1% /run/user/1000
When I run "mount" I got a lot more info. I attached a photo.
Mount
Galmo1
by mikeysklar on Mon Nov 29, 2021 4:55 pm
In your output from both the df and mount commands I cannot see your mounted filesystem for the video files you are playing. Are those files being stored on a USB drive? That drive should show up in the `df` output and the `mount` output. Your `mount` output is truncated due to the photo screenshot. If possible please paste in the full output from logging in remotely. You can run `mount | less` to get it to page one screen at a time and use space bar to continue.
mikeysklar
by Galmo1 on Wed Dec 08, 2021 6:50 pm
Yes, the files are being stored on a USD drive. As soon as I plug in the USB, the video looper starts working and plays the videos.
Also... I found a command that seemed to help!
I simply typed in 'Startx' then hit Enter, and it seems to do a reboot to the main screen. Hopefully that's a safe way to do it?
Galmo1
by mikeysklar on Thu Dec 09, 2021 3:45 pm
Interesting that running X helps. In that case you can set your Pi to just boot into X-windows by using raspi-config.
raspi-config
Boot Options --> Desktop / CLI --> Desktop Autologin
mikeysklar
