Trying for a simple solar setup with charging a backup battery.
Set up the bq24074 (Product ID: 4755) with the 6600mAh battery (Product ID: 353) and the PowerBoost 1000 Basic (Product ID: 2030) as the 'load'.
With the battery on the bq24074 and the PowerBoost connected to the Load (the PowerBoost itself has -nothing- connected, so its loading is minimal), with a 2Amp USB-C charger the Chg light never turns off on the bq24074.
If I disconnect the PowerBoost, the Chg light will turn off, so the bq24074 does appear to charge the battery when there is -0- load.
So should the bq24074 be able to charge the battery while a load is active?
Charging with bq24074 while load is active never completes?
- sigwx
- adafruit_support_bill
Re: Charging with bq24074 while load is active never complet
That sounds about right. The last phase of the LiPo charge cycle is a constant voltage 'trickle' charge to level out the charge across the cell. It completes when the current falls to zero. With any load connected, the current will never quite get to zero.
- sigwx
Good to know, thanks!
Now, then with 6600mAh, and an approx 300ma load after the PowerBoost, I get about 3-4 hrs after the sun goes down.
Any information on the operating efficiency on the PowerBoost? It seemed like things should have lasted longer.
What are you using for a solar panel?
- sigwx
An HQST 10w panel that claims 9.8V operating but 12v open. I've run that through a converter to get it down to 5V since the bq24074's protection circuit would shut it down if the panel ever did reach over 10V.
- sigwx
Though what I've noticed lately is that I can remove everything, connect the battery to the bq24074 and power the bq24074 from its USB-C connection, and the charge light isn't turning off anymore, even after 48 hours on a charge.
The battery is the Lithium Ion Battery Pack - 3.7V 6600mAh (Product ID: 353) which I thought has over-discharge protection, and the bq24074 should be handling over-charging. Is there a way to determine if there is a battery problem?
Disconnect the battery from the charger and measure the voltage on the battery leads. All our cells have protection circuits, so they should not go below about 3v.
48 hours on a USB power source with no load attached should be more than enough to charge that battery if it is healthy.
- sigwx
Battery is showing 4.1V with my meter, so it seems charged.
So it is charging, but the charge never finishes. Full charge should be 4.2V. But I have seen meters off by more than 0.1v. What voltage do you measure between the GND and VBus pins?
And with the battery connected and the charger powered, measure the voltage between the GND and LiPo pins..
- sigwx
Well, I tried a discharge test where I plugged the battery to the PowerBoost Basic 1000, and that to a ~100ma load, using a USB Voltage tester to track mAh consumed and the battery stopped at 3554 mAh
So it is definitely in a state where it will be charging, and for that I see 4.55v on VBus/Gnd and 2.78v between LiPo/Gnd waiting to see what that looks like after a few hours
VBus should be much closer to 5v. If the voltage of your power supply is sagging, most likely it is not able to source sufficient current.
You did not specify whether the LiPo/GND measurement was with the battery connected or not. But in either case, would not expect it to be below 3v.
- sigwx
After a few hours now, VBus is 4.9V and LiPo is 3.55V, battery connected.
The previous LiPo reading was with the battery connected.
Power is USB-C, 2Amp tested at 5.05V
Without a battery connected, VBus is 4.51V and the LiPo output is all over the map, ranging from 0.55V to 3.55V
VBus should only be a Schottky diode drop below your USB supply voltage. That would be about 4.7v.Without a battery connected, VBus is 4.51V and the LiPo output is all over the map, ranging from 0.55V to 3.55V
The LiPo connection on the charger will vary as it attempts to detect whether there is a chargeable batter connected.
What is the voltage across the battery itself now (disconnected from the charger)?
- sigwx
After an overnight charge, the battery disconnected is 3.87V
Putting it back on the bq24074, the LiPo output shows 3.87V and the VBus is 4.88V
We can try replacing the charger. If you purchased directly from us, you can contact [email protected]. Otherwise contact the seller. In either case, please include a link to this thread as authorization for a replacement.
