120 degree spy camera errors out
by jpspoonhower on Wed May 18, 2022 9:28 am
I am attempting to install an adafruit 120 degree spy camera onto a pi zero W running bullseye raspberry pi OS.
The pi zero runs headless; I connect using VNC.
The red led on the camera cable is lit, so power at least, is available to the camera. However, the camera fails with this error
when I run a command from a terminal:
libcamera-hello -t 0
libEGL warning: DRI2: failed to authenticate
Made X/EGL preview window
[0:03:19.326408576] [1109] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3424-e68e0f1e
ERROR: *** no cameras available ***
How do I correct this?
jpspoonhower
Re: 120 degree spy camera errors out
by mikeysklar on Wed May 18, 2022 7:08 pm
Just to confirm did you buy the model that is specifically for Pi Zeros?
https://www.adafruit.com/product/5389
Are you using a Pi Zero or Pi Zero 2?
mikeysklar
by jpspoonhower on Thu May 19, 2022 8:27 am
I am using a pi zero W (v1.1).
jpspoonhower
by mikeysklar on Thu May 19, 2022 5:58 pm
Assuming you are using adafruit product id# 5389 it should just be a configuration issue on your Pi.
Make sure you enable "Glamor" graphic acceleration. That appears to be the main culprit for this message.
sudo raspi-config
Advanced Options --> enable Glamor graphic acceleration
reboot.
mikeysklar
by jpspoonhower on Thu May 19, 2022 6:27 pm
I confirm the product is a p5389.
"Glamor" is enabled using raspi-config.
I get the same error.
jpspoonhower
by mikeysklar on Thu May 19, 2022 9:02 pm
Two more things to try:
1) make sure you fully updated.
sudo apt update
sudo apt full-upgrade
2) again go back to raspi-config and enable legacy camera. It is located under interface options.
reboot
mikeysklar
by jpspoonhower on Thu May 19, 2022 9:27 pm
1) sudo apt update and sudo apt full-upgrade were completed.
2) legacy camera support enabled in raspi-config.
3) reboot.
4) after boot, the red LED on the camera cable is no longer illuminated.
5) the VNC display size is changed (smaller display)
6) same error:
ibcamera-hello -t 0
[0:02:12.960370542] [1062] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3544-22656360
jpspoonhower
by mikeysklar on Thu May 19, 2022 11:47 pm
Okay, I see the issue.
There is conflict with using VNC and the camera.
Can you run the command over ssh?
mikeysklar
by jpspoonhower on Fri May 20, 2022 6:44 am
ssh shows the same result:
Preview window unavailable
[9:23:53.584064503] [1609] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3544-22656360
jpspoonhower
by mikeysklar on Fri May 20, 2022 4:28 pm
It no longer gives the original beginning of the error message?
It is now (via ssh) only the:
There are also other camera interfaces. You could try:
If you really want to use libcamera you might need to add a monitor / keyboard / mouse for troubleshooting purposes. I believe you need to have X running with a valid DISPLAY=:0 setting.
export DISPLAY=:0
mikeysklar
by jpspoonhower on Fri May 20, 2022 5:51 pm
Yes, with ssh the initial response is different. Is this a big surprise, given there is no X-window environment? I do not understand your point..
here is what raspistill produces:
pi@pizerocam:~ $ raspistill -o cam.jpeg
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
seems like the problem persists...
why does the red LED get disabled when legacy camera is enabled in raspi-config? seems bizarre to me.
jpspoonhower
by mikeysklar on Sat May 21, 2022 4:03 pm
Thanks for trying raspistill.
Let's get back to your original command:
libcamera-hello A simple "hello world" application which starts a camera preview stream and displays it on the screen.
It is failing to launch a preview window with no valid X11 display.
You have a few options:
1) Do you have a valid display to export to (another X11 machine)?
2) Plugin a keyboard/mouse/monitor to your Pi to confirm the command can run with its preview window on a local X11 environment.
3) Try libcamera-still which can omit the preview window.
libcamera-still A more complex still image capture application which emulates more of the features of raspistill.
https://www.raspberrypi.com/documentati ... amera.html
mikeysklar
by jpspoonhower on Sun May 22, 2022 11:16 am
I chose method #2.
from a terminal window on the desktop , here's the response.
pi@pizerocam:~ $ libcamera-hello -t 0
[0:03:17.334778766] [1098] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3544-22656360
pi@pizerocam:~ $ libcamera-still
[0:12:31.393368946] [1126] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3544-22656360
pi@pizerocam:~ $ raspistill -o cam.jpg
pi@pizerocam:~ $
It all looks like the same problem to me regardless of the working environment.
How do I return this camera for a credit?
I have spent way too much time on this....
jpspoonhower
by mikeysklar on Mon May 23, 2022 6:14 pm
Please contact support@adafruit.com requesting a refund. Include your invoice# and a link to this forum thread.
mikeysklar
