TLP5110
Post Reply
nineseventytwo
TLP5110
Post by nineseventytwo »
I purchased an Adafruit TLP5110 Lower Power Timer, a while ago. I'm getting around to using it. I followed the guide, and things were working, but now the timer has a very quick repeating flash on its timer LED. I have cut the trace for the Pot. I'm only measuring 1.9vdc coming from the DRV pin. I have 3.7vdc coming into VDD. My project is an ESP-01, powered after pushing the TPL5110, only to connect to Wifi and publish an MQTT message. Then the code toggles the Done pin to turn the power off.
dastels
Re: TLP5110
Post by dastels »
Make sure that setting up the DONE output is done as early as possible in the code. If it takes too long, the TPL can go into a weird state where it flashes like that. I've had it happen with CircuitPython code that took too long to setup DONE.
Franklin97355
Re: TLP5110
Post by Franklin97355 »
You might be interested in this video on the 5110 particular at 10-- minutes and beyond
Post Reply
