๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Problem with Eagle CAD and the TL082 opamp
by shobley on Tue Mar 10, 2009 4:40 pm
I've been learning Eagle CAD, and I recently tried to generate a board from a schematic with a TL082 opamp IC in it. The only problem is the power lines are not shown in the schematic, so I can't get it to hook up.
When I select the part it has power pins in the preview, but none on the schematic when placed. Is there a trick to getting this to show up?
Steve
http://www.stephenhobley.com
http://www.youtube.com/shobley
For all your laser harp, tesla coil, and killer robots from outer space needs.
shobley
Re: Problem with Eagle CAD and the TL082 opamp
by Amberwolf on Tue Mar 10, 2009 5:01 pm
I've not really used Eagle to create anything, just view existing projects and sometimes alter them for PCB printouts, but after about 5 minutes poking around at the tools I think you can do it by using the "invoke" tool, which looks like four NAND gates, at the lower-right of the second group of tools on the leftside toolbar.
Select that tool, then click on the opamp (or other part) you want to show the power/ground pins on.
A dialog pops up with that IC's available placeable pins/sections, anything unavailable is greyed out. Select the part you want, then left click on the schematic part you want to place it at. You probably don't even have to place them on the actual op-amp on the schematic to work, but it's easier to keep track of what they're for if you do.
EDIT: PS--how's the Dalek coming?
Watch me build an electric bike from assorted junk!
Alternative Energy Sources for the Home from Recycled Junk
A subsidiary of Cybernetic Necromancers, Discorporated:
"We Bring Dead Things To Life"
Amberwolf
by shobley on Tue Mar 10, 2009 6:07 pm
Thanks! That was it...
The Dalek's coming along, very very slowly... :D
shobley
by Amberwolf on Tue Mar 10, 2009 6:12 pm
I was a little afraid you'd given up on it, and that was why this story happened:
http://www.telegraph.co.uk/culture/tvan ... -pond.html
Amberwolf
