repeated soldering
repeated soldering
by dragonuv on Sun Mar 29, 2009 8:33 am
Ive bought a LCD screen & controller, and im willing to solder the wires to its pinout (because my wire is stranded and it is difficult to keep it without the wire being disconnected), is it recommended?
and is it ok if i solder the wires again so i can get them out?
and can this repeated soldering damage the lcd?
thanks.
dragonuv
Re: repeated soldering
by mtbf0 on Sun Mar 29, 2009 10:39 am
eventually you'll probably lift the solder pads off the circuit board.
mtbf0
by zener on Sun Mar 29, 2009 2:43 pm
Can you post a picture? I am unclear what you are trying to do. Soldering is like many things: "easy once you know how". What kind of iron do you have? Do you have some wick? Keep your temp down to avoid lifting the traces. Good advice is "get in, get out". The solder has a "working life". If the solder gets crusty, remove it and use fresh. And you don't want the wire insulation to melt either so another reason not to linger.
zener
by acquisition on Wed Apr 01, 2009 12:23 am
I would say get a male-male header and solder to the lcd. Then you can just leave it on there and do any soldering to the header. Or you can get a ribbon cable and connector.
acquisition
by dragonuv on Wed Apr 01, 2009 3:45 am
acquisition wrote:I would say get a male-male header and solder to the lcd. Then you can just leave it on there and do any soldering to the header. Or you can get a ribbon cable and connector.
great idea, thanks
dragonuv
cron
