solar panel amperage
by dragonuv on Wed Apr 01, 2009 7:46 am
is there a method of figuring what is the max amperage a solar panel can provide?
dragonuv
Re: solar panel amperage
by franklin97355 on Wed Apr 01, 2009 11:34 am
Here's one I found with a Google search. http://www.mtmscientific.com/solarpanel.html
franklin97355
by dragonuv on Thu Apr 02, 2009 1:45 pm
is it my ampermeter or i can't measure the amperage directly from the ampermeter? it shows only 0 whenever i use the 2 leads to check its amperage
dragonuv
by JohnOC on Thu Apr 02, 2009 2:21 pm
You should connect an ammeter in series with a load across the output of the solar panel. The meter by itself is like connecting the two leads of the panel to each other, a short circuit, and is probably not good for the panel.
JohnOC
by dragonuv on Thu Apr 02, 2009 3:28 pm
JohnOC wrote:You should connect an ammeter in series with a load across the output of the solar panel.
you mean anode,amp-meter,resistor,cathode ?
dragonuv
by zener on Sat Apr 04, 2009 2:06 am
dragonuv wrote:is it my ampermeter or i can't measure the amperage directly from the ampermeter? it shows only 0 whenever i use the 2 leads to check its amperage
Usually you have to put the red wire in a different hole in the meter. But I don't know what meter you have. If you have done this but measure no current then you have likely blown the fuse in the meter, or it was previously blown somehow.
zener
by zener on Sat Apr 04, 2009 2:08 am
Yes. And also you need another meter measuring the voltage across the resistor. This is to find the point of maximum power. However, you did not ask to do that so you might not care, I don't know. And make sure these resistors have enough wattage so they don't burn up if the panel is large. I don't know what panel you are using.
zener
