I'm going through the learn raspberry pi tutorials and this one doesn't appear to be working or I am in error. https://learn.adafruit.com/adafruits-ra ... rvo-motor/
It starts by saying the GPIO pin 18 will work for this on the hardware page, but makes no mention of pin 18 in the code at all. The code is also inconsistent for the set("mode") line between the top and the bottom of the software page. My script spits out "Error writing to: servo value: x" with x being an infinite loop between 0 and 180.
Can someone explain what I am missing? I'm sure it is something small, but the tutorial may need to be cleaned up or more explanatory as this is for noobs ;-)
Adafruit Learn example for servo + raspberry pi not working?
- lyric8
- caternuson
Re: Adafruit Learn example for servo + raspberry pi not work
Does this directory exist?
/sys/class/rpi-pwm/pwm0/
That tutorial is no longer accurate. The PWM signal on GPIO 18 stopped working when Raspbian moved from the Wheezy kernel to Jessie.
These days, you have to use software PWM, using a library like Rpi.GPIO.
- lyric8
Thank you. I thought I was taking crazy (strangely banned word, but you all know the phrase from Zoolander). I submitted the feedback that the tutorial is broken. Gracias!
- adafruit2
tutorial has been rewritten for modern raspbian, thx!
