Battery power for Rick & Morty portal gun
by MrBelm on Tue Apr 04, 2017 4:09 pm
I built a Rick & Morty portal gun based on this design:
http://www.thingiverse.com/thing:1100601
and this code:
https://github.com/pomeroyb/PortalGun
It uses a 5V 16 Mhz Pro Trinket with the LiPoly BackPack and a 3.7V LiPoly battery.
The problem I've encountered is that the LCD display (Quad Alphanumeric Display (Red 0.54")) lights up when the circuit is plugged into the Trinket's USB connection, but it doesn't light up when the circuit runs off the battery. I've charged the battery to full charge, but still no working LED. What could be an explanation for this behavior?
MrBelm
Re: Battery power for Rick & Morty portal gun
by adafruit_support_mike on Wed Apr 05, 2017 4:59 am
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
by MrBelm on Wed Apr 05, 2017 1:42 pm
I breadboarded and tested the circuit before final wiring. Here's the final layout:
MrBelm
by adafruit_support_mike on Thu Apr 06, 2017 3:49 am
Move the connection to the Perma Proto's VCC rail from the Pro Trinket's 5v pin to the BAT pin.
The 5v pin only gets power when a USB cable is connected. The BAT pin will have power at all times.
Other than that, your construction looks excellent.. well organized and very easy to read.
by MrBelm on Tue Apr 11, 2017 3:55 pm
That worked. Thanks!
MrBelm
by adafruit_support_mike on Wed Apr 12, 2017 3:03 am
Glad to hear it. Happy hacking!
by Meridoch on Mon Feb 12, 2018 7:51 am
Well I had the same issue and the fix worked. Thanks heaps!!
Meridoch
cron
