Room Occupancy Counter with VL53L0X
Re: Room Occupancy Counter with VL53L0X
by carsonf on Wed May 17, 2017 9:03 pm
Ok what the heck. I switched USB ports and it started working. :facepalm:
Thanks for your help Frank!
carsonf
by frankrnichols on Wed May 17, 2017 9:17 pm
No ideas except this general idea that I've used whenever troubleshooting code - since 1979,
Reduce your code to the simplest (fewest) lines you can that still exhibit the problem, and go from there.
Meanwhile, if I were you, I would slavishly copy my code (the clips I post/will post), which has been working just fine for months, and see where you get. If that works, then you can start looking for how your code differs.
Here is my simplest complete working code that spits out the ranges for TWO sensors in a loop.
I tested this (compiled, loaded my dual sensor Adafruit Feather M0 with 2 sensors) - FIVE MINUTES AGO
- 1 had one VL53L0X board's XSHUT/SHDN floating
- 1 had the other board's XSHUT/SHDN tied to '9' on the Feather M0
and as I moved my hand back and forth, just now, I saw this:
29,8190,23,170
29,8190,23,219
29,8190,23,8190
29,8190,23,8190
29,8190,23,8190
29,8190,23,226
29,8190,23,187
29,8190,23,159
29,17,23,141
29,0,23,128
29,59,23,126
29,111,23,8190
29,111,23,285
29,116,23,8190
29,134,23,8190
29,8190,23,8190
29,8190,23,8190
29,8190,23,8190
What follows is the ENTIRE SKETCH
#include <Arduino.h>
#include <SPI.h>
#if not defined (_VARIANT_ARDUINO_DUE_X_) && not defined (_VARIANT_ARDUINO_ZERO_)
  #include <SoftwareSerial.h>
#endif
#include <Wire.h>
#include <VL53L0X.h>
VL53L0X sensor29;
VL53L0X sensor23;
#define XSHDN_OF0X29  9
void setup()
  while (!Serial);  // required for Flora & Micro
  delay(500);
  Serial.begin(9600);
  Wire.begin();
  pinMode(XSHDN_OF0X29, OUTPUT);
  digitalWrite(XSHDN_OF0X29, LOW);
  delay(100);
  sensor23.setAddress(0x23);
  delay(10); // for good luck?
  digitalWrite(XSHDN_OF0X29, HIGH); // should now have two addresses on the I2C
  sensor23.init();
  sensor23.setTimeout(500);
  sensor23.startContinuous();
  sensor29.init();
  sensor29.setTimeout(500);
  sensor29.startContinuous();
void loop(void)
  Serial.print("29,");
  Serial.print(sensor29.readRangeContinuousMillimeters());
  if (sensor29.timeoutOccurred())
    Serial.print(" TIMEOUT 29");
  Serial.print(",23,");
  Serial.println(sensor23.readRangeContinuousMillimeters());
  if (sensor23.timeoutOccurred())
    Serial.print(" TIMEOUT 23");
  delay(100);
frankrnichols
by frankrnichols on Wed May 17, 2017 9:19 pm
Cool.
Glad you got it working.
frankrnichols
by chipou on Mon Jun 05, 2017 7:16 pm
Hello everybody,
I am working on the same issues with the sensor VL53L0X with arduino. For the moment I am making the test with only one sensor but I am getting the same result 65535
and it doesn't change.
I read your comments but I didn't really understand what I need to change.
Any help please?
Thank you very much
chipou
by toasterking on Fri Jun 16, 2017 12:00 am
@carsonf, I'm curious how this project worked out for you. I had read the same blog entry you linked about people counting and had the same thought, that I could do it better with ToF sensors rather than infrared. I was thinking I would try mounting 2 of these VL53L0X sensors on the ceiling on each side of the doorway for a total of 4 per door. In addition to checking the direction of movement, the distance detection could be used to judge whether the movement is an adult, child, or pet traversing the doorway (based on their height), or just the door being closed or opened.
Did this approach work out for you? Did you hit any snags other than setting up initial communication and sensor IDs?
toasterking
by adafruit2 on Thu Jun 29, 2017 4:24 pm
guide and source code have been updated with multi-sensor support
https://learn.adafruit.com/adafruit-vl5 ... le-sensors
adafruit2
Site Admin
by toasterking on Thu Jun 29, 2017 4:31 pm
adafruit2 wrote:guide and source code have been updated with multi-sensor support
Thanks, @adafruit2! You're a hero! :D
I no longer have any reasons not to buy some VL53L0X units. :-)
toasterking
