I really need your help :)
Is it possible to change the speed of the output of the pictures.
Because i made a different Project with the double staff programm and it spins much faster than you would spin a staff.
so the picture which i want to display is not to see like it should look like.
Would be really glad about help, thank you.
If you need some more details, just ask.
Valerian
Thats the program :)
#include <Adafruit_CircuitPlayground.h>
#include <Arduino.h>
#include <Adafruit_DotStar.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <SPI.h>
typedef uint16_t line_t;
// CONFIGURABLE STUFF ------------------------------------------------------
#include "graphics.h" // Graphics data is contained in this header file.
// It's generated using the 'convert.py' Python script. Various image
// formats are supported, trading off color fidelity for PROGMEM space.
// Handles 1-, 4- and 8-bit-per-pixel palette-based images, plus 24-bit
// truecolor. 1- and 4-bit palettes can be altered in RAM while running
// to provide additional colors, but be mindful of peak & average current
// draw if you do that! Power limiting is normally done in convert.py
// (keeps this code relatively small & fast).
// Ideally you use hardware SPI as it's much faster, though limited to
// specific pins. If you really need to bitbang DotStar data & clock on
// different pins, optionally define those here:
#define LED_DATA_PIN 12
#define LED_CLOCK_PIN 6
// Empty and full thresholds (millivolts) used for battery level display:
#define BATT_MIN_MV 3350 // Some headroom over battery cutoff near 2.9V
#define BATT_MAX_MV 4000 // And little below fresh-charged battery near 4.1V
boolean autoCycle = true; // Set to true to cycle images by default
#define CYCLE_TIME 5 // Time, in seconds, between auto-cycle images
#define IR_PIN 3 // MUST be INT1 pin!
// Adafruit IR Remote Codes:
// Button Code Button Code
// VOL-: 0x0000 0/10+: 0x000C
// Play/Pause: 0x0001 1: 0x0010
// VOL+: 0x0002 2: 0x0011
// SETUP: 0x0004 3: 0x0012
// STOP/MODE: 0x0006 4: 0x0014
// UP: 0x0005 5: 0x0015
// DOWN: 0x000D 6: 0x0016
// LEFT: 0x0008 7: 0x0018
// RIGHT: 0x000A 8: 0x0019
// ENTER/SAVE: 0x0009 9: 0x001A
// Back: 0x000E
#define BTN_BRIGHT_UP 0x0002
#define BTN_BRIGHT_DOWN 0x0000
#define BTN_RESTART 0x0001
#define BTN_BATTERY 0x0004
#define BTN_FASTER 0x0005
#define BTN_SLOWER 0x000D
#define BTN_OFF 0x0006
#define BTN_PATTERN_PREV 0x0008
#define BTN_PATTERN_NEXT 0x000A
#define BTN_NONE 0xFFFF
#define BTN_AUTOPLAY 0x0009
#if defined(LED_DATA_PIN) && defined(LED_CLOCK_PIN)
// Older DotStar LEDs use GBR order. If colors are wrong, edit here.
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS,
LED_DATA_PIN, LED_CLOCK_PIN, DOTSTAR_BGR);
#else
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DOTSTAR_BGR);
#endif
void imageInit(void),
IRinterrupt(void),
showBatteryLevel(void);
uint16_t readVoltage(void);
CircuitPlayground.begin();
strip.begin(); // Allocate DotStar buffer, init SPI
strip.clear(); // Make sure strip is clear
strip.show(); // before measuring battery
showBatteryLevel();
imageInit(); // Initialize pointers for default image
attachInterrupt(1, IRinterrupt, CHANGE); // IR remote interrupt
void showBatteryLevel(void) {
// Display battery level bargraph on startup. It's just a vague estimate
// based on cell voltage (drops with discharge) but doesn't handle curve.
uint16_t mV = readVoltage();
uint8_t lvl = (mV >= BATT_MAX_MV) ? NUM_LEDS : // Full (or nearly)
(mV <= BATT_MIN_MV) ? 1 : // Drained
1 + ((mV - BATT_MIN_MV) * NUM_LEDS + (NUM_LEDS / 2)) /
(BATT_MAX_MV - BATT_MIN_MV + 1); // # LEDs lit (1-NUM_LEDS)
for(uint8_t i=0; i<lvl; i++) { // Each LED to batt level...
uint8_t g = (i * 5 + 2) / NUM_LEDS; // Red to green
strip.setPixelColor(i, 4-g, g, 0);
strip.show(); // Animate a bit
delay(250 / NUM_LEDS);
delay(1500); // Hold last state a moment
strip.clear(); // Then clear strip
strip.show();
// GLOBAL STATE STUFF ------------------------------------------------------
uint32_t lastImageTime = 0L, // Time of last image change
lastLineTime = 0L;
uint8_t imageNumber = 0, // Current image being displayed
imageType, // Image type: PALETTE[1,4,8] or TRUECOLOR
*imagePalette, // -> palette data in PROGMEM
*imagePixels, // -> pixel data in PROGMEM
palette[16][3]; // RAM-based color table for 1- or 4-bit images
line_t imageLines, // Number of lines in active image
imageLine; // Current line number in image
volatile uint16_t irCode = BTN_NONE; // Last valid IR code received
const uint8_t PROGMEM brightness[] = { 15, 31, 63, 127, 255 };
uint8_t bLevel = sizeof(brightness) - 1;
// Microseconds per line for various speed settings
const uint16_t PROGMEM lineTable[] = { // 375 * 2^(n/3)
1000000L / 375, // 375 lines/sec = slowest
1000000L / 472,
1000000L / 595,
1000000L / 750, // 750 lines/sec = mid
1000000L / 945,
1000000L / 1191,
1000000L / 1500 // 1500 lines/sec = fastest
uint8_t lineIntervalIndex = 3;
uint16_t lineInterval = 1000000L / 750;
void imageInit() { // Initialize global image state for current imageNumber
imageType = pgm_read_byte(&images[imageNumber].type);
imageLines = pgm_read_word(&images[imageNumber].lines);
imageLine = 0;
imagePalette = (uint8_t *)pgm_read_word(&images[imageNumber].palette);
imagePixels = (uint8_t *)pgm_read_word(&images[imageNumber].pixels);
// 1- and 4-bit images have their color palette loaded into RAM both for
// faster access and to allow dynamic color changing. Not done w/8-bit
// because that would require inordinate RAM (328P could handle it, but
// I'd rather keep the RAM free for other features in the future).
if(imageType == PALETTE1) memcpy_P(palette, imagePalette, 2 * 3);
else if(imageType == PALETTE4) memcpy_P(palette, imagePalette, 16 * 3);
lastImageTime = millis(); // Save time of image init for next auto-cycle
void nextImage(void) {
if(++imageNumber >= NUM_IMAGES) imageNumber = 0;
imageInit();
void prevImage(void) {
imageNumber = imageNumber ? imageNumber - 1 : NUM_IMAGES - 1;
imageInit();
// MAIN LOOP ---------------------------------------------------------------
CircuitPlayground.setPixelColor(0, 255, 0, 0);
CircuitPlayground.setPixelColor(1, 128, 12 , 0);
CircuitPlayground.setPixelColor(2, 0, 255, 0);
CircuitPlayground.setPixelColor(3, 0, 128, 128);
CircuitPlayground.setPixelColor(4, 0, 0, 255);
CircuitPlayground.setPixelColor(5, 0xFF0000);
CircuitPlayground.setPixelColor(6, 0x808000);
CircuitPlayground.setPixelColor(7, 0x00FF00);
CircuitPlayground.setPixelColor(8, 0x008080);
CircuitPlayground.setPixelColor(9, 0x0000FF);
uint32_t t = millis(); // Current time, milliseconds
if(autoCycle) {
if((t - lastImageTime) >= (CYCLE_TIME * 1000L)) nextImage();
// CPU clocks vary slightly; multiple poi won't stay in perfect sync.
// Keep this in mind when using auto-cycle mode, you may want to cull
// the image selection to avoid unintentional regrettable combinations.
// Transfer one scanline from pixel data to LED strip:
// If you're really pressed for graphics space and need just a few extra
// scanlines, and know for a fact you won't be using certain image modes,
// you can comment out the corresponding blocks below. e.g. disabling
// PALETTE8 and TRUECOLOR support can free up nearly 200 bytes of extra
// image storage.
switch(imageType) {
case PALETTE1: { // 1-bit (2 color) palette-based image
uint8_t pixelNum = 0, byteNum, bitNum, pixels, idx,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 8];
for(byteNum = NUM_LEDS/8; byteNum--; ) { // Always padded to next byte
pixels = pgm_read_byte(ptr++); // 8 pixels of data (pixel 0 = LSB)
for(bitNum = 8; bitNum--; pixels >>= 1) {
idx = pixels & 1; // Color table index for pixel (0 or 1)
strip.setPixelColor(pixelNum++,
palette[idx][0], palette[idx][1], palette[idx][2]);
break;
case PALETTE4: { // 4-bit (16 color) palette-based image
uint8_t pixelNum, p1, p2,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 2];
for(pixelNum = 0; pixelNum < NUM_LEDS; ) {
p2 = pgm_read_byte(ptr++); // Data for two pixels...
p1 = p2 >> 4; // Shift down 4 bits for first pixel
p2 &= 0x0F; // Mask out low 4 bits for second pixel
palette[p1][0], palette[p1][1], palette[p1][2]);
palette[p2][0], palette[p2][1], palette[p2][2]);
break;
case PALETTE8: { // 8-bit (256 color) PROGMEM-palette-based image
uint16_t o;
uint8_t pixelNum,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS];
for(pixelNum = 0; pixelNum < NUM_LEDS; pixelNum++) {
o = pgm_read_byte(ptr++) * 3; // Offset into imagePalette
strip.setPixelColor(pixelNum,
pgm_read_byte(&imagePalette[o]),
pgm_read_byte(&imagePalette[o + 1]),
pgm_read_byte(&imagePalette[o + 2]));
break;
case TRUECOLOR: { // 24-bit ('truecolor') image (no palette)
uint8_t pixelNum, r, g, b,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS * 3];
r = pgm_read_byte(ptr++);
g = pgm_read_byte(ptr++);
b = pgm_read_byte(ptr++);
strip.setPixelColor(pixelNum, r, g, b);
break;
if(++imageLine >= imageLines) imageLine = 0; // Next scanline, wrap around
while(((t = micros()) - lastLineTime) < lineInterval) {
if(irCode != BTN_NONE) {
if(!strip.getBrightness()) { // If strip is off...
// Set brightness to last level
strip.setBrightness(pgm_read_byte(&brightness[bLevel]));
// and ignore button press (don't fall through)
// effectively, first press is 'wake'
} else {
switch(irCode) {
case BTN_BRIGHT_UP:
if(bLevel < (sizeof(brightness) - 1))
strip.setBrightness(pgm_read_byte(&brightness[++bLevel]));
break;
case BTN_BRIGHT_DOWN:
if(bLevel)
strip.setBrightness(pgm_read_byte(&brightness[--bLevel]));
break;
case BTN_FASTER:
if(lineIntervalIndex < (sizeof(lineTable) / sizeof(lineTable[0]) - 1))
lineInterval = pgm_read_word(&lineTable[++lineIntervalIndex]);
break;
case BTN_SLOWER:
if(lineIntervalIndex)
lineInterval = pgm_read_word(&lineTable[--lineIntervalIndex]);
break;
case BTN_RESTART:
imageNumber = 0;
imageInit();
break;
case BTN_BATTERY:
strip.clear();
strip.show();
delay(250);
strip.setBrightness(255);
showBatteryLevel();
break;
case BTN_OFF:
strip.setBrightness(0);
break;
case BTN_PATTERN_PREV:
prevImage();
break;
case BTN_PATTERN_NEXT:
nextImage();
break;
case BTN_AUTOPLAY:
autoCycle = !autoCycle;
break;
irCode = BTN_NONE;
strip.show(); // Refresh LEDs
lastLineTime = t;
void IRinterrupt() {
static uint32_t pulseStartTime = 0, pulseDuration = 0;
static uint8_t irValue, irBits, irBytes, irBuf[4];
uint32_t t = micros();
if(PIND & 0b00001000) { // Low-to-high (start of new pulse)
pulseStartTime = t;
} else { // High-to-low (end of current pulse)
uint32_t pulseDuration = t - pulseStartTime;
if((pulseDuration > 4000) && (pulseDuration < 5000)) { // ~4.5 ms?
irValue = irBits = irBytes = 0; // IR code start, reset counters
} else if(pulseDuration < 2500) { // Data bit?
irValue >>= 1; // Shift data in, LSB first
if(pulseDuration >= 1125) irValue |= 0x80; // Longer pulse = 1
if((++irBits == 8) && (irBytes < 4)) { // Full byte recv'd?
irBuf[irBytes] = irValue; // Store byte
irValue = irBits = 0; // and reset counters
if((++irBytes == 4) && ((irBuf[2] ^ irBuf[3]) == 0xFF)) {
uint16_t code = 0xFFFF;
if((irBuf[0] ^ irBuf[1]) == 0xFF) {
irCode = (irBuf[0] << 8) | irBuf[1];
} else if((irBuf[0] == 0) && (irBuf[1] == 0xBF)) {
irCode = irBuf[2];
// Battery monitoring idea adapted from JeeLabs article:
// jeelabs.org/2012/05/04/measuring-vcc-via-the-bandgap/
// Code from Adafruit TimeSquare project, added Trinket support.
// In a pinch, the poi code can work on a 3V Trinket, but the battery
// monitor will not work correctly (due to the 3.3V regulator), so
// maybe just comment out any reference to this code in that case.
uint16_t readVoltage() {
int i, prev;
uint8_t count;
uint16_t mV;
// Select AVcc voltage reference + Bandgap (1.8V) input
ADMUX = _BV(REFS0) |
_BV(MUX3) | _BV(MUX2) | _BV(MUX1);
ADCSRA = _BV(ADEN) | // Enable ADC
_BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0); // 1/128 prescaler (125 KHz)
// Datasheet notes that the first bandgap reading is usually garbage as
// voltages are stabilizing. It practice, it seems to take a bit longer
// than that. Tried various delays, but still inconsistent and kludgey.
// Instead, repeated readings are taken until four concurrent readings
// stabilize within 10 mV.
for(prev=9999, count=0; count<4; ) {
for(ADCSRA |= _BV(ADSC); ADCSRA & _BV(ADSC); ); // Start, await ADC conv.
i = ADC; // Result
mV = i ? (1100L * 1023 / i) : 0; // Scale to millivolts
if(abs((int)mV - prev) <= 10) count++; // +1 stable reading
else count = 0; // too much change, start over
prev = mV;
ADCSRA = 0; // ADC off
return mV;
