Touch Switch Momentary
- drewsonian
I am pretty new to this, and I'm interested in using your momentary touch switch sensor to control my under cabinet lights. I'm using the Fibaro RGBW to control LED strips (Adafruit's btw :-D) and I believe what I need is to connect your AT42QT1010 module to a relay that simply closes the GND and IN pins on the Fibaro. Does that sound right? I know you don't carry the Fibaro unit but if I need something that simply closes a circuit, is it a relay that I need? If so, any suggestions on which one or what else might do the trick?
Re: Touch Switch Momentary
There are several ways to do that kind of thing, but relays are one option.
What voltage and current do your lights use?
- drewsonian
The LED lights are 12V and the LED strips will draw around 6-8 amps when turned on fully, I believe.adafruit_support_mike wrote:There are several ways to do that kind of thing, but relays are one option.
You can also use mosfets for those:
https://learn.adafruit.com/rgb-led-strips/usage
They're faster and more durable than relays.
- drewsonian
Thanks - and if I have 12V available, how do I run the momentary touch switch since it takes 1.8 to 5.5VDC ?
You'd need a 5v regulator like this one:
https://www.adafruit.com/product/2236
along with a couple of capacitors to keep the voltage stable.. one at the input, and one at the output. The datasheet linked from the Technical Details section of the page above has a digram that shows what you'll need (page 4).
