I have two DS18B20 temperature sensors that I'm using with a Raspberry Pi 3. I wired and I'm using it at it says so in the guide for using it on a RPi :https://learn.adafruit.com/adafruits-ra ... ng/ds18b20
I did modify the code by a bit to get the readings of two of these DS18B20 sensors.
They both connect fine and I can read the temperature readings just fine but when I leave it running for a few hours and come back I get this error:
I ran the code several times and it always happens after a couple hours, could this be a power issue that's causing this or anyone know the cause of this problem?IOError: [Errno 2] No such file or directory: '/sys/bus/w1/devices/28-000008e0f6af/w1_slave'
