I’ve got purchased a PITFT 3.5 2441.
I’ve got readed your tutorial
https://learn.adafruit.com/adafruit-pit ... q?view=all
I’ve got downloaded the image full, lite 23 sept 2016 and I tried it with:
A RPI zero W
RPI 3
RPI 2+
RPI 2
But the screen remain White.
So I’ve got downloaded an old version of image, since 2016-03-25 with the same result.
Can you Help me ?
Thank you very much.
Kind regards
PiTFT Plus 480x320 3.5"
Re: PiTFT Plus 480x320 3.5"
Try starting with the latest version of Raspbian:
https://www.raspberrypi.org/downloads/raspbian/
Then add PiTFT support on top of it using the instructions from the Easy-install page. There have been several hardware changes in the PiTFT line in the last year, and the preconfigured OS images are mostly for historical purposes these days.
- dichkinn
Thank you for your answer
But I'm no lucky because I've got followed the instructions of easy install procedure.
first, I've got checked scripted version ans the screen remain White
second, I've checked manually with the same result, white screen :-(
Can you help me ?
Kind regards
Can you help me ?
Kind regards
Post a photo showing the back of the PiTFT where the flex cable enters the connector, along with the output from `dmesg` please.
800x600 images work best, and text output is easier to read between CODE tags.
- dichkinn
thank you for your answer.
Here you con find the files to check my config.
Best regards
Best regards
- Attachments
- Photography connector
- 20170814_094959_resized.jpg (997.94 KiB) Viewed 810 times
- dsmeg.txt
- dsmeg result
- (19.98 KiB) Downloaded 30 times
Sorry, I meant this side:
There are also some problems in the dmesg output you posted. None of the kernel drivers for the TFT or the touchscreen are there.
Try installing PiTFT support again, using the instructions here:
https://learn.adafruit.com/adafruit-pit ... ler-script
- dichkinn
Now I've got perform a new install
and I ollow the step 1 to step 3
the screen still white, but I've got take a new capture of dmesg (linked bellow)
and I've got see more error.
Strange because It' a new instalaltion.
Little precision, for the installation I use a VGA adaptator for HDMI.
Perhaps this is it cause trouble ?
Thank you for your Help.
Kind regards
Kind regards
- Attachments
- 20170815_122721_resized.jpg (955.55 KiB) Viewed 765 times
- dmesg-new.txt
- (25.13 KiB) Downloaded 44 times
The output from dmesg does show the drivers for the PiTFT and touchscreen, so that much is good.
In the photo, the black tabs at both ends of the flex cable connector are loose:
Make sure the flex cable is in the connector as far as it will go, then push the tabs toward the connector to lock the cable in place.
- dichkinn
great now it work very well.
The problem was cable connector :-)
thank you very much for your support
Kind regards
Kind regards
Glad to hear that did it. Happy hacking!
