Need coding help for REZZ glasses
Re: Need coding help for REZZ glasses
@EAGON - I only want the STL if it's built the way OP's is... in a way that fits the rings. I'm guessing yours is a very different shape. If you posted a screenshot of the render, I could look it over and see if I'm assuming incorrectly. I'd definitely be able to help with code if it's the right shape and you'd trade the STL.
- bpmoore178
@kcl1s - I'm also in the process of making some Rezz HypnoShades and was able to run your your code on my kludged together setup. I did however encounter an issue: the middle (16x RGBW led rings) spin in a different direction than the outermost (24x RGBW led rings).
My question: How can I make all rings spin in the same direction? Eg: all three rings spinning counterclockwise or clockwise?
Here's a quick outline of my setup:
Controller: Gemma M0
Wiring:
Here's my setup running your code: https://youtu.be/xzgqnP-NDEk
Thanks for the help! -Brian
Wiring:
- Left 24x RGBW ring ---> D0(soldiered)
- Right 24x RGBW ring ---> D0(soldiered)
- Left 16x RGBW ring ---> Left 24x data out pin
- Right 16x RGBW ring ---> Right 24x data out pin
- Left 7x RGBW Jewel ---> Left 16x data out pin
- Right 7x RGBW Jewel ---> Right 16x data out pin
- kcl1s
My code was written for RGB Neopixels. You say you have RGBW. Did you change the code to reflect that difference? You have to change the code where you define your Neopixel strip and also the wheel() function.
Keith
Keith
- bpmoore178
@Kcl1s- Thanks for getting back to me so quickly. I made the following modifications to your code:
Changed the NeoPixel type to RGBW:
Added Adafruit's NeoPixel Gamma correction code:
Finally: If you wouldn't mind, can you elaborate on what you mean by wheel() function? I'm assuming you mean this bit of code below but i'm not entirely sure I understand what it's purpose is:
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRBW + NEO_KHZ800);
byte neopix_gamma[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
- kcl1s
The wheel function I have in my code and you posted above is for RGB pixels. They return 3 color values. The RGBW pixels use 4 values so the wheel function is returning bad data.
Use this code which is the wheel function for RGBW pixels. It still does not use the white component but includes a '0' value for white so the data is correct.
Keith
//Wheel code for RGBW pixels
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3,0);
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3,0);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0,0);
uint8_t red(uint32_t c) {
return (c >> 8);
uint8_t green(uint32_t c) {
return (c >> 16);
uint8_t blue(uint32_t c) {
return (c);
- bpmoore178
@Kcl1s- Thanks for the modification! I was originally encountering compile errors and needed to change your scope of "pixles" to "strip" to get everything working again. That being said, the outer and middle rings are still rotating in opposite directions. Ultimately, I'm still curious as to how to reverse this so all rings rotate in the same direction. Any help appreciated.
-Brian
-Brian
- kcl1s
It looks like the ring pcb is made so the pixels increase in number in a counter clockwise direction. I have never seen that before.
I have not tested this but you could try changing the 4 - 16 ring code lines like this...
Keith
// for ccw rings add '16 -' to the 4 - 16 pixel lines
//from this
pixels.setPixelColor(LstepCt * 16 / 256 + Lmid, Wheel(wC));
//to this
pixels.setPixelColor(16 - LstepCt * 16 / 256 + Lmid, Wheel(wC));
Keith
- EAGON
Yeah, mine is different. It is more like the ones that she has. I am still making adjustments to it so it is not perfect yet but you can see my 3D model here and all the parts are there too, you can explode or turn parts off. Im using individually addressable RGB leds from sparkfun and a trinket, with the powerboost 500c with a 3.7v lipo from an old project.
http://a360.co/2yCgi7R
- NMAN124
I attempted a very similar project and have not been able to get my 3D model to print correctly. May I use yours? It's a personal project and I would appreciate it very much!
- hakstyle
I know this is an older post but I'm also trying to make the same glasses and am having trouble creating a 3D model.
Would anyone know where I can get an .stl file or any format so I can 3D print the frame? Or can anyone kindly send me theirs? Thank you in advance!
- zambam
I'm working on this project too, I have the .stl files pretty much done for 2 x 24 NP ring, 2 x 16 NP Ring, and 8 individual NP leds. I'm completely stuck on the coding, I'm using a nr52 feather board and planning to tuck it all inside a box.
Do you have any help to offer on the wiring, coding side?
hakstyle wrote:I know this is an older post but I'm also trying to make the same glasses and am having trouble creating a 3D model.
- ivanmakca
DO you think I could get the STL files for the glasses?zambam wrote:I'm working on this project too, I have the .stl files pretty much done for 2 x 24 NP ring, 2 x 16 NP Ring, and 8 individual NP leds. I'm completely stuck on the coding, I'm using a nr52 feather board and planning to tuck it all inside a box.
- ivanmakca
Is it possible for you to share your STL file for the frame for the glasses? I desperately need it, im trying to create the glasses for my girlfriend that loves Rezz. Thanksbpmoore178 wrote:@Kcl1s- Thanks for the modification! I was originally encountering compile errors and needed to change your scope of "pixles" to "strip" to get everything working again. That being said, the outer and middle rings are still rotating in opposite directions. Ultimately, I'm still curious as to how to reverse this so all rings rotate in the same direction. Any help appreciated.
-Brian
- VKingMoneyMaker
anybody have the STL file?
