Raspberry pi zero w not booting.
- techie84
I recently bought a pi zero w and upon testing it there was no booting up or any response. So i checked other peoples forums post and tried just connecting the USB up to my laptop to see if the computer would pick it up but it did not. I had loaded Retro-pie onto the SD card and made sure i had the right files on it. It seems to me this is just a defective board. But please any suggestions on what i haven't tried or did wrong. Please help I have been trying to do a project with this but i am stuck without this board or a possible replacement.
- Attachments
- Untitled.png (741.82 KiB) Viewed 199 times
- adafruit_support_carter
Re: Raspberry pi zero w not booting.
Looks like you are doing the sanity test check correctly. Here's the general process:
https://learn.adafruit.com/raspberry-pi ... -zero-dead
The other thing to try would be different USB cables and USB ports.
https://www.raspberrypi.org/downloads/raspbian/
Could be an out of date image, bad image, or even bad SD card. For testing purposes, best thing is to try using the latest Raspbian Lite image from here:I had loaded Retro-pie onto the SD card and made sure i had the right files on it.
- techie84
I have tried 5 different USB wires trying to see if it would work but no luck. I have tried all that i know to do. I also just got another pi zero but not the Pi zero W but the first Gen. It arrived on yesterday and i have used the regular Pi zero many times before with no issues at all. But again another one that does not work. I am curious why your company mails these boards in a flimsy plastic bubble envelope when all other retailers that sell your boards that i have purchased from mail them in a small cardboard box and all of the ones I have received worked perfectly. Do i need to start another forum post for the other Pi zero i received yesterday.
Keep in mind that the Zero W requires newer version of the OS than the original Zero. This has tripped some people up who've tried moving a working SD card from a Zero to a Zero W, and it wouldn't work. Just mentioning this as it sound like you are working with both models.
So at this point you are having issues with a Zero W and an original Zero, from two separate orders? Were both received in the bubble envelopes?
Please post photos of the non-functioning boards. If there is any noticeable damage, please point it out.
