Hallo,
First, I hope I posted it in the correct Forum.
I am thinking about building an audio output to my Nanopi Neo. I thought this soundcard https://learn.adafruit.com/assets/28850 wich is an enhanced version from here https://learn.adafruit.com/introducing- ... io-outputs would suite my need most perfectly.
The only problem is, that I do not understand, what the 'DAC_2' connector is. Maybe one of you is able to help me :)
In referenz to "How to Add Audio Outputs to your Pi Zero"
- utnefgnvuefn
- adafruit_support_carter
Re: In referenz to "How to Add Audio Outputs to your Pi Zero
It's the component video out. For audio, you can ignore it.
- utnefgnvuefn
Thank you for the answer!
So I can ignore the whole part with the COMPVID and BAV99?
Unfortunately I came upon two more questions.
First, what are PP25 and PP26?
Second, where do I get the 2.5V for the AUD_2V5? There is no 2.5V GPIO, as far as I know. Would a simple voltage regulator work?
For what you are trying to do, yes.So I can ignore the whole part with the COMPVID and BAV99?
Test pads. In general, you can ignore those as well.First, what are PP25 and PP26?
Dunno. Must come from somewhere on the board that's not shown in the schematics:Second, where do I get the 2.5V for the AUD_2V5? There is no 2.5V GPIO, as far as I know. Would a simple voltage regulator work?
https://www.raspberrypi.org/documentati ... matics.pdf
- utnefgnvuefn
Thank you very much for your help!
I posted a question at the raspberrypi.org forum.
