Black Lives Matter - Action and Equality.
Buttons
Buttons
by kotchi on Mon Sep 07, 2009 10:57 pm
First i would like to add that i am really new to all this, so bear with me.
I'm having trouble with some buttons.
I understand how the tact switch that comes with the arduino works. It switches beetwen grounded (G) and 5 volv (V), deciding wich one will be connected to the digital I/O.
Now i'm building a small project where i'm planning on using larger buttons than small tact switches.
The one i have looks like this.
With only 2 legs, opens when pushed, closed otherwise. Now the problem i have is that i can only connect it to either G or V because one leg always needs to go to the I/O.
Now i tried connecting one to V and the other one to I/O but i can never get any good HIGH or LOW readings. Sometimes i can push it once and it switches between HIGH and LOW, but wont work the second time i push it. Or it just switches between HIGH/LOW like crazy.
Is there a way to get a good read from these kind of switches or am i using it wrong, or is there some other kind of button more suitable for this kind of work.
Any help would be appreciated.
kotchi
Re: Buttons
by len17 on Tue Sep 08, 2009 12:18 am
You need to use a pull-up or pull-down resistor so that the input pin isn't left "floating" when the switch is open.
The Arduino conveniently has a built-in pull-up resistor for each input pin, but you have to add a line of code to turn it on. Then you can connect the switch from the input pin to ground. Here's a sketch that shows how it works:
#define pinInSwitch 5
void setup()
  Serial.begin(57600);
  pinMode(pinInSwitch, INPUT);
  digitalWrite(pinInSwitch, HIGH); // turn on pull-up resistor
void loop()
  if (digitalRead(pinInSwitch) == LOW) {
    Serial.println("LOW");
  } else {
    Serial.println("HIGH");
len17
Re: Buttons
by kotchi on Tue Sep 08, 2009 8:09 am
Thanks, now its working.
kotchi
Re: Buttons
by adafruit on Tue Sep 08, 2009 5:46 pm
Re: Buttons
by kotchi on Thu Sep 10, 2009 9:00 am
Yeah, i read that one and understood how it worked with a tact switch. But i couldnt get a button with only two legs to work and needed that one line to turn on the pull up resistor (digitalWrite(pinInSwitch, HIGH);).
I have run into another problem now, so i thought i should place it in the same topic since its the same project.
I'm trying to print something on my lcd. The word 'arming' to be precise. I got the printing part down, even made a timer so far. The problem is this:
I can write;
lcd.print("ARMIN");
and it will print it, and everything else will show. But if i try to spell the entire word:
lcd.print("ARMING");
The lcd wont print anything, or it will show random characters/signs. But the rest of the code runs. Buzzer/light etc.
And i am pulling my hair out because i just cant understand why it wont work.
I've tried printing other words and it seems the limit of characters is 5. But i have printed longer words/sentences before that.
kotchi
Re: Buttons
I can write;
lcd.print("ARMIN");
kotchi
Re: Buttons
by kotchi on Thu Sep 10, 2009 10:06 am
Made some progress, it seems that it works if i enter a longer sentence. Could there be a reason for this? Is there like a minimum or maximum amount of characters?
If i write a word between 6-10 characters it doesnt work. But i can write say "ODA-903" and it works. It just feels completely random.
kotchi
Re: Buttons
by mtbf0 on Thu Sep 10, 2009 10:51 am
well that's just plain bizarre. can we see the code with a little context.
or you could hyphenate "arm-ing."
mtbf0
Re: Buttons
by mike31416 on Thu Sep 10, 2009 11:04 am
Memory corruption?
mike31416
