Adafruit "Music Maker" MP3 Shield Doesn't Make Play Anything
by Dog1111111 on Sat Nov 18, 2017 5:01 pm
I just purchased a Music Maker shield and it does not work at all. I can read from the SD card and I can load the shield but no noise comes out.
I tried using this line of code to see if the shield could output any audio and it doesn't do anything.
musicPlayer.sineTest(0x44, 500);
Here is the program I am testing with:
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
int n_files;
int led = 9;
void setup()
  Serial.begin(9600);
  Serial.println("Ready, Start!");
  pinMode(led, OUTPUT);
  pinMode(2,INPUT_PULLUP);
  // initialise the music player
  if (! musicPlayer.begin()) { // initialise the music player
    Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
    while (1);
  Serial.println(F("VS1053 chip found..."));
  Serial.println("Playing note");
  musicPlayer.setVolume(1,1);
  delay(6000);
  musicPlayer.sineTest(0x44, 500);    // Make a tone to indicate VS1053 is working
  if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  Serial.println("SD Card Loaded...");
  Serial.println();
  n_files = countMP3File(SD.open("/"));
  Serial.print("Number of MP3 files: ");
  Serial.println(n_files);
  Serial.println();
int countMP3File(File dir)
  int counter = 0;
  Serial.println("Listing files:");
  while(true)
    File entry = dir.openNextFile();
    if (! entry)
      dir.rewindDirectory();
      break;
    Serial.println(entry.name());
    counter++;
    entry.close();
  dir.close();
  Serial.println();
  return counter;
void loop()
  int i, rand_song;
  Serial.print("Motion Sensor Val: ");
  Serial.println(digitalRead(2));
  if (true)//digitalRead(2) == 0)
    File folder = SD.open("/");
    File random_file;
    rand_song = random(0, n_files)+1;
    folder.rewindDirectory();
    random_file = selectFileN(rand_song, folder);
    folder.close();
    Serial.print("Playing: ");
    Serial.println(random_file.name());
    // smoke machine
    //digitalWrite(led, LOW);
    if(!musicPlayer.playFullFile(random_file.name()))
      Serial.println("Could not open mp3 file");
    random_file.close();
    // stop smoke machine
    //digitalWrite(led, HIGH);
    Serial.println("Waiting 6 sec...");
    delay(6000);
  Serial.println();
  delay(100);
File selectFileN(int number, File dir)
  int counter = 0;
  File return_entry;
  while(true)
    if (! entry)
      //Serial.println("Last file reached");
      break;
    //Serial.println(entry.name());
    counter++;
    if(counter==number)
      return_entry = entry;
      break;
    entry.close();
  return return_entry;
Most of the code does not work. I do not insert an micro SD.
I am just trying to get a noise from the sine test to work and I get nothing.
I am using an arduino uno and 4ohm 3 watt speakers.
Dog1111111
Re: Adafruit "Music Maker" MP3 Shield Doesn't Make Play Anyt
by adafruit_support_mike on Sat Nov 18, 2017 5:39 pm
I see some exposed gold on some of the PCB pads for the pin header, which often means the pin isn’t making a good electrical connection.
Take a look at our soldering tutorial:
https://learn.adafruit.com/adafruit-gui ... ring/tools
and give the joints another pass with a bit ot flux.
by Dog1111111 on Sat Nov 18, 2017 8:10 pm
So I went over all the pins and got rid of all the gold. But there is still no noise playing when I run the program. I cannot figure out what is wrong.
Here are two pictures of the new sodder:
Dog1111111
by adafruit_support_mike on Wed Nov 22, 2017 4:21 am
Those joints look good.
What kind of Arduino are you using under the Music Maker?
by Dog1111111 on Wed Nov 22, 2017 4:01 pm
A Arduino UNO
Dog1111111
by adafruit_support_mike on Thu Nov 23, 2017 12:58 am
That should work with the default SPI connections.
Looking back at the photos, I see what might be a bit of solder shorting one of the control signals:
Check to see if the resistor in the center is shorted, and if it is, remove the short.
