Playground Express
Playground Express
by Temani3 on Sat Nov 18, 2017 9:13 pm
I’m currently dealing with the Playground Express. I’m trying to upload sketches from the Examples (specifically the IR examples) but, for some reason it does not compile. The error reads “Error Compiling for Board AdaFruit Circuit PlayGround express”.
Every thing is set correctly; IDE is showing “CPX on COM9” and I’ve installed every library with “Adafruit” or “Circuit Playground” in it. Everything in my device manager checks out fine..
I have some TX/RX projects in mind that I would love to use this for so, I would really appreciate you guys help!
Temani3
Re: Playground Express
by adafruit_support_mike on Sun Nov 19, 2017 12:36 am
Open the Arduino IDE's preferences window, enable verbose messages during compilation and upload, and post the error messages from the debugger pane when you try to upload (between CODE tags please). We'll see what those have to say.
by Temani3 on Tue Nov 21, 2017 2:18 am
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Delicia\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Delicia\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Delicia\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_circuitplayground_m0 -ide-version=10801 -build-path C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -prefs=runtime.tools.bossac.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -verbose C:\Users\Delicia\Documents\Arduino\libraries\arduino_633263\examples\Infrared_NeoPixel\Infrared_NeoPixel.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Delicia\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Delicia\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Delicia\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_circuitplayground_m0 -ide-version=10801 -build-path C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -prefs=runtime.tools.bossac.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -verbose C:\Users\Delicia\Documents\Arduino\libraries\arduino_633263\examples\Infrared_NeoPixel\Infrared_NeoPixel.ino
Using board 'adafruit_circuitplayground_m0' from platform in folder: C:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21
Using core 'arduino' from platform in folder: C:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21
Detecting libraries used...
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987\sketch\Infrared_NeoPixel.ino.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987\sketch\Infrared_NeoPixel.ino.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987\sketch\Infrared_NeoPixel.ino.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987\sketch\Infrared_NeoPixel.ino.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\Adafruit_CircuitPlayground.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\Adafruit_CPlay_LIS3DH.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\Adafruit_CPlay_Mic.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\Adafruit_CPlay_NeoPixel.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\Adafruit_CPlay_Speaker.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\CP_Firmata.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\CPlay_CapacitiveSensor.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\esp8266.c" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\ffft.S" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility" "C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground\utility\talkie.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "C:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire\Wire.cpp" -o "nul"
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "C:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI\SPI.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD  -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DADAFRUIT_CIRCUITPLAYGROUND_M0 -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\cores\arduino" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\variants\circuitplay" "-IC:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire" "-IC:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI" "C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987\sketch\Infrared_NeoPixel.ino.cpp" -o "C:\Users\Delicia\AppData\Local\Temp\arduino_build_266987\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground/utility/CP_Firmata.h:17:0,
                 from C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground/Adafruit_CircuitPlayground.h:23,
                 from C:\Users\Delicia\Documents\Arduino\libraries\arduino_633263\examples\Infrared_NeoPixel\Infrared_NeoPixel.ino:18:
C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground/utility/CP_Boards.h:708:2: error: #error "Please edit Boards.h with a hardware abstraction for this board"
Multiple libraries were found for "Adafruit_CircuitPlayground.h"
 Used: C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground
 Not used: C:\Users\Delicia\Documents\Arduino\libraries\arduino_633263
 Not used: C:\Users\Delicia\Documents\Arduino\libraries\arduino_473939
 Not used: C:\Users\Delicia\Documents\Arduino\libraries\Adafruit_Circuit_Playground
 Not used: C:\Users\Delicia\Documents\Arduino\libraries\Adafruit_CircuitPlayground-master
 Not used: C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground-master
Using library Adafruit_CircuitPlayground at version 1.6.4 in folder: C:\Program Files (x86)\Arduino\libraries\Adafruit_CircuitPlayground
Using library Wire at version 1.0 in folder: C:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\Delicia\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.21\libraries\SPI
exit status 1
Error compiling for board Adafruit Circuit Playground Express.
Temani3
by adafruit_support_mike on Tue Nov 21, 2017 3:39 am
It looks like you have an older version of the Circuit Playground library. The current version has a board description for the Circuit Playground Express in the file that generated those errors:
https://github.com/adafruit/Adafruit_CircuitPlayground
by Temani3 on Tue Nov 21, 2017 2:40 pm
I Downloaded the library from the link you sent, unzipped it & saved it to the libraries section of the Arduino folder. Once I restarted the IDE, I tried to Compile the IR Neopixel example & it gave me the same compile error.
Temani3
by adafruit_support_mike on Wed Nov 22, 2017 12:13 am
Hmm.. could you post the contents of the file:
from the library you downloaded (between CODE tags please)?
by Temani3 on Wed Nov 22, 2017 6:33 am
  Boards.h - Hardware Abstraction Layer for Firmata library
  Copyright (c) 2006-2008 Hans-Christoph Steiner.  All rights reserved.
  Copyright (C) 2009-2016 Jeff Hoefs.  All rights reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  See file LICENSE.txt for further informations on licensing terms.
  Last updated April 10th, 2016
#ifndef Firmata_Boards_h
#define Firmata_Boards_h
#include <inttypes.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"  // for digitalRead, digitalWrite, etc
#else
#include "WProgram.h"
#endif
// Normally Servo.h must be included before Firmata.h (which then includes
// this file).  If Servo.h wasn't included, this allows the code to still
// compile, but without support for any Servos.  Hopefully that's what the
// user intended by not including Servo.h
#ifndef MAX_SERVOS
#define MAX_SERVOS 0
#endif
    Firmata Hardware Abstraction Layer
Firmata is built on top of the hardware abstraction functions of Arduino,
specifically digitalWrite, digitalRead, analogWrite, analogRead, and
pinMode.  While these functions offer simple integer pin numbers, Firmata
needs more information than is provided by Arduino.  This file provides
all other hardware specific details.  To make Firmata support a new board,
only this file should require editing.
The key concept is every "pin" implemented by Firmata may be mapped to
any pin as implemented by Arduino.  Usually a simple 1-to-1 mapping is
best, but such mapping should not be assumed.  This hardware abstraction
layer allows Firmata to implement any number of pins which map onto the
Arduino implemented pins in almost any arbitrary way.
General Constants:
These constants provide basic information Firmata requires.
TOTAL_PINS: The total number of pins Firmata implemented by Firmata.
    Usually this will match the number of pins the Arduino functions
    implement, including any pins pins capable of analog or digital.
    However, Firmata may implement any number of pins.  For example,
    on Arduino Mini with 8 analog inputs, 6 of these may be used
    for digital functions, and 2 are analog only.  On such boards,
    Firmata can implement more pins than Arduino's pinMode()
    function, in order to accommodate those special pins.  The
    Firmata protocol supports a maximum of 128 pins, so this
    constant must not exceed 128.
TOTAL_ANALOG_PINS: The total number of analog input pins implemented.
    The Firmata protocol allows up to 16 analog inputs, accessed
    using offsets 0 to 15.  Because Firmata presents the analog
    inputs using different offsets than the actual pin numbers
    (a legacy of Arduino's analogRead function, and the way the
    analog input capable pins are physically labeled on all
    Arduino boards), the total number of analog input signals
    must be specified.  16 is the maximum.
VERSION_BLINK_PIN: When Firmata starts up, it will blink the version
    number.  This constant is the Arduino pin number where a
    LED is connected.
Pin Mapping Macros:
These macros provide the mapping between pins as implemented by
Firmata protocol and the actual pin numbers used by the Arduino
functions.  Even though such mappings are often simple, pin
numbers received by Firmata protocol should always be used as
input to these macros, and the result of the macro should be
used with with any Arduino function.
When Firmata is extended to support a new pin mode or feature,
a pair of macros should be added and used for all hardware
access.  For simple 1:1 mapping, these macros add no actual
overhead, yet their consistent use allows source code which
uses them consistently to be easily adapted to all other boards
with different requirements.
IS_PIN_XXXX(pin): The IS_PIN macros resolve to true or non-zero
    if a pin as implemented by Firmata corresponds to a pin
    that actually implements the named feature.
PIN_TO_XXXX(pin): The PIN_TO macros translate pin numbers as
    implemented by Firmata to the pin numbers needed as inputs
    to the Arduino functions.  The corresponding IS_PIN macro
    should always be tested before using a PIN_TO macro, so
    these macros only need to handle valid Firmata pin
    numbers for the named feature.
Port Access Inline Funtions:
For efficiency, Firmata protocol provides access to digital
input and output pins grouped by 8 bit ports.  When these
groups of 8 correspond to actual 8 bit ports as implemented
by the hardware, these inline functions can provide high
speed direct port access.  Otherwise, a default implementation
using 8 calls to digitalWrite or digitalRead is used.
When porting Firmata to a new board, it is recommended to
use the default functions first and focus only on the constants
and macros above.  When those are working, if optimized port
access is desired, these inline functions may be extended.
The recommended approach defines a symbol indicating which
optimization to use, and then conditional complication is
used within these functions.
readPort(port, bitmask):  Read an 8 bit port, returning the value.
   port:    The port number, Firmata pins port*8 to port*8+7
   bitmask: The actual pins to read, indicated by 1 bits.
writePort(port, value, bitmask):  Write an 8 bit port.
   value:   The 8 bit value to write
   bitmask: The actual pins to write, indicated by 1 bits.
 * Board Specific Configuration
#ifndef digitalPinHasPWM
#define digitalPinHasPWM(p)     IS_PIN_DIGITAL(p)
#endif
// Arduino Duemilanove, Diecimila, and NG
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328__)
#if defined(NUM_ANALOG_INPUTS) && NUM_ANALOG_INPUTS == 6
#define TOTAL_ANALOG_PINS       6
#define TOTAL_PINS              20 // 14 digital + 6 analog
#else
#define TOTAL_ANALOG_PINS       8
#define TOTAL_PINS              22 // 14 digital + 8 analog
#endif
#define VERSION_BLINK_PIN       13
#define IS_PIN_DIGITAL(p)       ((p) >= 2 && (p) <= 19)
#define IS_PIN_ANALOG(p)        ((p) >= 14 && (p) < 14 + TOTAL_ANALOG_PINS)
#define IS_PIN_PWM(p)           digitalPinHasPWM(p)
#define IS_PIN_SERVO(p)         (IS_PIN_DIGITAL(p) && (p) - 2 < MAX_SERVOS)
#define IS_PIN_I2C(p)           ((p) == 18 || (p) == 19)
#define IS_PIN_SPI(p)           ((p) == SS || (p) == MOSI || (p) == MISO || (p) == SCK)
#define PIN_TO_DIGITAL(p)       (p)
#define PIN_TO_ANALOG(p)        ((p) - 14)
#define PIN_TO_PWM(p)           PIN_TO_DIGITAL(p)
#define PIN_TO_SERVO(p)         ((p) - 2)
#define ARDUINO_PINOUT_OPTIMIZE 1
// Wiring (and board)
#elif defined(WIRING)
#define VERSION_BLINK_PIN       WLED
#define IS_PIN_DIGITAL(p)       ((p) >= 0 && (p) < TOTAL_PINS)
#define IS_PIN_ANALOG(p)        ((p) >= FIRST_ANALOG_PIN && (p) < (FIRST_ANALOG_PIN+TOTAL_ANALOG_PINS))
#define IS_PIN_SERVO(p)         ((p) >= 0 && (p) < MAX_SERVOS)
#define IS_PIN_I2C(p)           ((p) == SDA || (p) == SCL)
#define PIN_TO_ANALOG(p)        ((p) - FIRST_ANALOG_PIN)
#define PIN_TO_SERVO(p)         (p)
// old Arduinos
#elif defined(__AVR_ATmega8__)
#define IS_PIN_ANALOG(p)        ((p) >= 14 && (p) <= 19)
// Arduino Mega
#elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define TOTAL_ANALOG_PINS       16
#define TOTAL_PINS              70 // 54 digital + 16 analog
#define PIN_SERIAL1_RX          19
#define PIN_SERIAL1_TX          18
#define PIN_SERIAL2_RX          17
#define PIN_SERIAL2_TX          16
#define PIN_SERIAL3_RX          15
#define PIN_SERIAL3_TX          14
#define IS_PIN_DIGITAL(p)       ((p) >= 2 && (p) < TOTAL_PINS)
#define IS_PIN_ANALOG(p)        ((p) >= 54 && (p) < TOTAL_PINS)
#define IS_PIN_SERVO(p)         ((p) >= 2 && (p) - 2 < MAX_SERVOS)
#define IS_PIN_I2C(p)           ((p) == 20 || (p) == 21)
#define IS_PIN_SERIAL(p)        ((p) > 13 && (p) < 20)
#define PIN_TO_ANALOG(p)        ((p) - 54)
// Arduino DUE
#elif defined(__SAM3X8E__)
#define TOTAL_ANALOG_PINS       12
#define TOTAL_PINS              66 // 54 digital + 12 analog
#define IS_PIN_I2C(p)           ((p) == 20 || (p) == 21) // 70 71
// Arduino/Genuino MKR1000
#elif defined(ARDUINO_SAMD_MKR1000)
#define TOTAL_ANALOG_PINS       7
#define TOTAL_PINS              22 // 8 digital + 3 spi + 2 i2c + 2 uart + 7 analog
#define IS_PIN_DIGITAL(p)       (((p) >= 0 && (p) <= 21) && !IS_PIN_SERIAL(p))
#define IS_PIN_ANALOG(p)        ((p) >= 15 && (p) < 15 + TOTAL_ANALOG_PINS)
#define IS_PIN_SERVO(p)         (IS_PIN_DIGITAL(p) && (p) < MAX_SERVOS) // deprecated since v2.4
#define IS_PIN_I2C(p)           ((p) == 11 || (p) == 12) // SDA = 11, SCL = 12
#define IS_PIN_SERIAL(p)        ((p) == PIN_SERIAL1_RX || (p) == PIN_SERIAL1_TX) //defined in variant.h  RX = 13, TX = 14
#define PIN_TO_ANALOG(p)        ((p) - 15)
#define PIN_TO_SERVO(p)         (p) // deprecated since v2.4
// Arduino Zero
// Note this will work with an Arduino Zero Pro, but not with an Arduino M0 Pro
// Arduino M0 Pro does not properly map pins to the board labeled pin numbers
#elif defined(_VARIANT_ARDUINO_ZERO_)
#define TOTAL_PINS              25 // 14 digital + 6 analog + 2 i2c + 3 spi
#define TOTAL_PORTS             3  // set when TOTAL_PINS > num digitial I/O pins
#define VERSION_BLINK_PIN       LED_BUILTIN
//#define PIN_SERIAL1_RX          0 // already defined in zero core variant.h
//#define PIN_SERIAL1_TX          1 // already defined in zero core variant.h
#define IS_PIN_DIGITAL(p)       ((p) >= 0 && (p) <= 19)
#define IS_PIN_I2C(p)           ((p) == 20 || (p) == 21) // SDA = 20, SCL = 21
#define IS_PIN_SPI(p)           ((p) == SS || (p) == MOSI || (p) == MISO || (p) == SCK) // SS = A2
#define IS_PIN_SERIAL(p)        ((p) == 0 || (p) == 1)
// Arduino 101
#elif defined(_VARIANT_ARDUINO_101_X_)
#define TOTAL_ANALOG_PINS       NUM_ANALOG_INPUTS
#define TOTAL_PINS              NUM_DIGITAL_PINS // 15 digital (including ATN pin) + 6 analog
#define IS_PIN_DIGITAL(p)       ((p) >= 0 && (p) <= 20)
#define IS_PIN_PWM(p)           digitalPinHasPWM(p) // 3, 5, 6, 9
#define IS_PIN_I2C(p)           ((p) == SDA || (p) == SCL) // SDA = 18, SCL = 19
// Teensy 1.0
#elif defined(__AVR_AT90USB162__)
#define TOTAL_ANALOG_PINS       0
#define TOTAL_PINS              21 // 21 digital + no analog
#define VERSION_BLINK_PIN       6
#define PIN_SERIAL1_RX          2
#define PIN_SERIAL1_TX          3
#define IS_PIN_ANALOG(p)        (0)
#define IS_PIN_I2C(p)           (0)
#define IS_PIN_SERIAL(p)        ((p) == 2 || (p) == 3)
#define PIN_TO_ANALOG(p)        (0)
// Teensy 2.0
#elif defined(__AVR_ATmega32U4__) && defined(CORE_TEENSY)
#define TOTAL_PINS              25 // 11 digital + 12 analog
#define VERSION_BLINK_PIN       11
#define PIN_SERIAL1_RX          7
#define PIN_SERIAL1_TX          8
#define IS_PIN_ANALOG(p)        ((p) >= 11 && (p) <= 22)
#define IS_PIN_I2C(p)           ((p) == 5 || (p) == 6)
#define IS_PIN_SERIAL(p)        ((p) == 7 || (p) == 8)
#define PIN_TO_ANALOG(p)        (((p) < 22) ? 21 - (p) : 11)
// Teensy 3.0, 3.1 and 3.2
#elif defined(__MK20DX128__) || defined(__MK20DX256__)
#define TOTAL_ANALOG_PINS       14
#define TOTAL_PINS              38 // 24 digital + 10 analog-digital + 4 analog
#define PIN_SERIAL2_RX          9
#define PIN_SERIAL2_TX          10
#define PIN_SERIAL3_RX          7
#define PIN_SERIAL3_TX          8
#define IS_PIN_DIGITAL(p)       ((p) >= 0 && (p) <= 33)
#define IS_PIN_ANALOG(p)        (((p) >= 14 && (p) <= 23) || ((p) >= 34 && (p) <= 38))
#define IS_PIN_SERIAL(p)        (((p) > 6 && (p) < 11) || ((p) == 0 || (p) == 1))
#define PIN_TO_ANALOG(p)        (((p) <= 23) ? (p) - 14 : (p) - 24)
// Teensy-LC
#elif defined(__MKL26Z64__)
#define TOTAL_ANALOG_PINS       13
#define TOTAL_PINS              27 // 27 digital + 13 analog-digital
#define IS_PIN_DIGITAL(p)       ((p) >= 0 && (p) <= 26)
#define IS_PIN_ANALOG(p)        ((p) >= 14)
// Teensy++ 1.0 and 2.0
#elif defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
#define TOTAL_PINS              46 // 38 digital + 8 analog
#define IS_PIN_ANALOG(p)        ((p) >= 38 && (p) < TOTAL_PINS)
#define IS_PIN_I2C(p)           ((p) == 0 || (p) == 1)
#define PIN_TO_ANALOG(p)        ((p) - 38)
// Leonardo
#define TOTAL_PINS              30 // 14 digital + 12 analog + 4 SPI (D14-D17 on ISP header)
#define IS_PIN_ANALOG(p)        ((p) >= 18 && (p) < TOTAL_PINS)
#define IS_PIN_PWM(p)           ((p) == 3 || (p) == 5 || (p) == 6 || (p) == 9 || (p) == 10 || (p) == 11 || (p) == 13)
#define IS_PIN_I2C(p)           ((p) == 2 || (p) == 3)
#define PIN_TO_ANALOG(p)        (p) - 18
// Intel Galileo Board (gen 1 and 2) and Intel Edison
#elif defined(ARDUINO_LINUX)
// RedBearLab BLE Nano with factory switch settings (S1 - S10)
#elif defined(BLE_NANO)
#define TOTAL_PINS              15 // 9 digital + 3 analog
#define IS_PIN_DIGITAL(p)       ((p) >= 2 && (p) <= 14)
#define IS_PIN_ANALOG(p)        ((p) == 8 || (p) == 9 || (p) == 10 || (p) == 11 || (p) == 12 || (p) == 14) //A0~A5
#define IS_PIN_PWM(p)           ((p) == 3 || (p) == 5 || (p) == 6)
#define IS_PIN_SERVO(p)         ((p) >= 2 && (p) <= 7)
#define IS_PIN_SPI(p)           ((p) == CS || (p) == MOSI || (p) == MISO || (p) == SCK)
#define PIN_TO_ANALOG(p)        ((p) - 8)
// Sanguino
#elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644__)
#define TOTAL_PINS              32 // 24 digital + 8 analog
#define VERSION_BLINK_PIN       0
#define IS_PIN_ANALOG(p)        ((p) >= 24 && (p) < TOTAL_PINS)
#define IS_PIN_I2C(p)           ((p) == 16 || (p) == 17)
#define PIN_TO_ANALOG(p)        ((p) - 24)
// Illuminato
#elif defined(__AVR_ATmega645__)
#define TOTAL_PINS              42 // 36 digital + 6 analog
#define IS_PIN_ANALOG(p)        ((p) >= 36 && (p) < TOTAL_PINS)
#define IS_PIN_I2C(p)           ((p) == 4 || (p) == 5)
#define PIN_TO_ANALOG(p)        ((p) - 36)
// Pic32 chipKIT FubarinoSD
#elif defined(_BOARD_FUBARINO_SD_)
#define TOTAL_ANALOG_PINS       NUM_ANALOG_PINS  // 15
#define TOTAL_PINS              NUM_DIGITAL_PINS // 45, All pins can be digital
#define MAX_SERVOS              NUM_DIGITAL_PINS
#define VERSION_BLINK_PIN       PIN_LED1
#define IS_PIN_DIGITAL(p)       1
#define IS_PIN_ANALOG(p)        ((p) >= 30 && (p) <= 44)
#define IS_PIN_PWM(p)           IS_PIN_DIGITAL(p)
#define IS_PIN_SERVO(p)         IS_PIN_DIGITAL(p)
#define IS_PIN_I2C(p)           ((p) == 1 || (p) == 2)
#define PIN_TO_ANALOG(p)        (14 - (p - 30))
#define PIN_TO_PWM(p)           (p)
// Pic32 chipKIT FubarinoMini
// Note, FubarinoMini analog pin 20 will not function in Firmata as analog input due to limitation in analog mapping
#elif defined(_BOARD_FUBARINO_MINI_)
#define TOTAL_ANALOG_PINS       14 // We have to fake this because of the poor analog pin mapping planning in FubarinoMini
#define TOTAL_PINS              NUM_DIGITAL_PINS // 33
#define IS_PIN_DIGITAL(p)       ((p) != 14 && (p) != 15 && (p) != 31 && (p) != 32)
#define IS_PIN_ANALOG(p)        ((p) == 0 || ((p) >= 3 && (p) <= 13))
#define IS_PIN_I2C(p)           ((p) == 25 || (p) == 26)
// Pic32 chipKIT UNO32
#elif defined(_BOARD_UNO_) && defined(__PIC32)  // NOTE: no _BOARD_UNO32_ to use
#define TOTAL_ANALOG_PINS       NUM_ANALOG_PINS // 12
#define TOTAL_PINS              NUM_DIGITAL_PINS // 47 All pins can be digital
#define MAX_SERVOS              NUM_DIGITAL_PINS // All pins can be servo with SoftPWMservo
#define IS_PIN_DIGITAL(p)       ((p) >= 2)
#define IS_PIN_ANALOG(p)        ((p) >= 14 && (p) <= 25)
#define IS_PIN_I2C(p)           ((p) == 45 || (p) == 46)
// Pic32 chipKIT DP32
#elif defined(_BOARD_DP32_)
#define TOTAL_ANALOG_PINS       15  // Really only has 9, but have to override because of mistake in variant file
#define TOTAL_PINS              NUM_DIGITAL_PINS // 19
#define IS_PIN_DIGITAL(p)       (((p) != 1) && ((p) != 4) && ((p) != 5) && ((p) != 15) && ((p) != 16))
#define IS_PIN_ANALOG(p)        ((p) >= 6 && (p) <= 14)
// Pic32 chipKIT uC32
#elif defined(_BOARD_UC32_)
// Pic32 chipKIT WF32
#elif defined(_BOARD_WF32_)
#define IS_PIN_DIGITAL(p)       ((p) >= 2 && (p) <= 49)     // Accounts for SD and WiFi dedicated pins
#define IS_PIN_I2C(p)           ((p) == 34 || (p) == 35)
// Pic32 chipKIT WiFire
#elif defined(_BOARD_WIFIRE_)
#define TOTAL_ANALOG_PINS       NUM_ANALOG_PINS  // 14
#define TOTAL_PINS              NUM_DIGITAL_PINS // 71
#define IS_PIN_DIGITAL(p)       ((p) >= 2 && (p) <= 47)     // Accounts for SD and WiFi dedicated pins
#define PIN_TO_ANALOG(p)        ((p) <= 25 ? ((p) - 14) : (p) - 36)
// Pic32 chipKIT MAX32
#elif defined(_BOARD_MEGA_) && defined(__PIC32)  // NOTE: no _BOARD_MAX32_ to use
#define TOTAL_ANALOG_PINS       NUM_ANALOG_PINS  // 16
#define TOTAL_PINS              NUM_DIGITAL_PINS // 87
#define IS_PIN_ANALOG(p)        ((p) >= 54 && (p) <= 69)
// Pic32 chipKIT Pi
#elif defined(_BOARD_CHIPKIT_PI_)
#define IS_PIN_DIGITAL(p)       (((p) >= 2) && ((p) <= 3) || (((p) >= 8) && ((p) <= 13)) || (((p) >= 14) && ((p) <= 17)))
#define IS_PIN_ANALOG(p)        ((p) >= 14 && (p) <= 17)
#define PIN_TO_ANALOG(p)        ((p) <= 15 ? (p) - 14 : (p) - 12)
//#define PIN_TO_ANALOG(p)        (((p) <= 16) ? ((p) - 14) : ((p) - 16))
// Pinoccio Scout
// Note: digital pins 9-16 are usable but not labeled on the board numerically.
// SS=9, MOSI=10, MISO=11, SCK=12, RX1=13, TX1=14, SCL=15, SDA=16
#elif defined(ARDUINO_PINOCCIO)
#define TOTAL_PINS              NUM_DIGITAL_PINS // 32
#define VERSION_BLINK_PIN       23
#define PIN_SERIAL1_RX          13
#define PIN_SERIAL1_TX          14
#define IS_PIN_DIGITAL(p)       (((p) >= 2) && ((p) <= 16)) || (((p) >= 24) && ((p) <= 31))
#define IS_PIN_ANALOG(p)        ((p) >= 24 && (p) <= 31)
#define IS_PIN_I2C(p)           ((p) == SCL || (p) == SDA)
#define IS_PIN_SERIAL(p)        ((p) == 13 || (p) == 14)
// ESP8266
// note: boot mode GPIOs 0, 2 and 15 can be used as outputs, GPIOs 6-11 are in use for flash IO
#elif defined(ESP8266)
#define TOTAL_PINS              A0 + NUM_ANALOG_INPUTS
#define PIN_SERIAL_RX           3
#define PIN_SERIAL_TX           1
#define IS_PIN_DIGITAL(p)       (((p) >= 0 && (p) <= 5) || ((p) >= 12 && (p) < A0))
#define IS_PIN_ANALOG(p)        ((p) >= A0 && (p) < A0 + NUM_ANALOG_INPUTS)
#define IS_PIN_INTERRUPT(p)     (digitalPinToInterrupt(p) > NOT_AN_INTERRUPT)
#define IS_PIN_SERIAL(p)        ((p) == PIN_SERIAL_RX || (p) == PIN_SERIAL_TX)
#define PIN_TO_ANALOG(p)        ((p) - A0)
#define DEFAULT_PWM_RESOLUTION  10
// Circuit Playground Express
#elif defined(__SAMD21G18A__)
// anything else
#else
#error "Please edit CP_Boards.h with a hardware abstraction for this board"
#endif
// as long this is not defined for all boards:
#ifndef IS_PIN_SPI
#define IS_PIN_SPI(p)           0
#endif
#ifndef IS_PIN_SERIAL
#define IS_PIN_SERIAL(p)        0
#endif
#ifndef DEFAULT_PWM_RESOLUTION
#define DEFAULT_PWM_RESOLUTION  8
#endif
 * readPort() - Read an 8 bit port
static inline unsigned char readPort(byte, byte) __attribute__((always_inline, unused));
static inline unsigned char readPort(byte port, byte bitmask)
#if defined(ARDUINO_PINOUT_OPTIMIZE)
  if (port == 0) return (PIND & 0xFC) & bitmask; // ignore Rx/Tx 0/1
  if (port == 1) return ((PINB & 0x3F) | ((PINC & 0x03) << 6)) & bitmask;
  if (port == 2) return ((PINC & 0x3C) >> 2) & bitmask;
  return 0;
#else
  unsigned char out = 0, pin = port * 8;
  if (IS_PIN_DIGITAL(pin + 0) && (bitmask & 0x01) && digitalRead(PIN_TO_DIGITAL(pin + 0))) out |= 0x01;
  if (IS_PIN_DIGITAL(pin + 1) && (bitmask & 0x02) && digitalRead(PIN_TO_DIGITAL(pin + 1))) out |= 0x02;
  if (IS_PIN_DIGITAL(pin + 2) && (bitmask & 0x04) && digitalRead(PIN_TO_DIGITAL(pin + 2))) out |= 0x04;
  if (IS_PIN_DIGITAL(pin + 3) && (bitmask & 0x08) && digitalRead(PIN_TO_DIGITAL(pin + 3))) out |= 0x08;
  if (IS_PIN_DIGITAL(pin + 4) && (bitmask & 0x10) && digitalRead(PIN_TO_DIGITAL(pin + 4))) out |= 0x10;
  if (IS_PIN_DIGITAL(pin + 5) && (bitmask & 0x20) && digitalRead(PIN_TO_DIGITAL(pin + 5))) out |= 0x20;
  if (IS_PIN_DIGITAL(pin + 6) && (bitmask & 0x40) && digitalRead(PIN_TO_DIGITAL(pin + 6))) out |= 0x40;
  if (IS_PIN_DIGITAL(pin + 7) && (bitmask & 0x80) && digitalRead(PIN_TO_DIGITAL(pin + 7))) out |= 0x80;
  return out;
#endif
 * writePort() - Write an 8 bit port, only touch pins specified by a bitmask
static inline unsigned char writePort(byte, byte, byte) __attribute__((always_inline, unused));
static inline unsigned char writePort(byte port, byte value, byte bitmask)
  if (port == 0) {
    bitmask = bitmask & 0xFC;  // do not touch Tx & Rx pins
    byte valD = value & bitmask;
    byte maskD = ~bitmask;
    cli();
    PORTD = (PORTD & maskD) | valD;
    sei();
  } else if (port == 1) {
    byte valB = (value & bitmask) & 0x3F;
    byte valC = (value & bitmask) >> 6;
    byte maskB = ~(bitmask & 0x3F);
    byte maskC = ~((bitmask & 0xC0) >> 6);
    cli();
    PORTB = (PORTB & maskB) | valB;
    PORTC = (PORTC & maskC) | valC;
    sei();
  } else if (port == 2) {
    bitmask = bitmask & 0x0F;
    byte valC = (value & bitmask) << 2;
    byte maskC = ~(bitmask << 2);
    cli();
    sei();
  return 1;
#else
  byte pin = port * 8;
  if ((bitmask & 0x01)) digitalWrite(PIN_TO_DIGITAL(pin + 0), (value & 0x01));
  if ((bitmask & 0x02)) digitalWrite(PIN_TO_DIGITAL(pin + 1), (value & 0x02));
  if ((bitmask & 0x04)) digitalWrite(PIN_TO_DIGITAL(pin + 2), (value & 0x04));
  if ((bitmask & 0x08)) digitalWrite(PIN_TO_DIGITAL(pin + 3), (value & 0x08));
  if ((bitmask & 0x10)) digitalWrite(PIN_TO_DIGITAL(pin + 4), (value & 0x10));
  if ((bitmask & 0x20)) digitalWrite(PIN_TO_DIGITAL(pin + 5), (value & 0x20));
  if ((bitmask & 0x40)) digitalWrite(PIN_TO_DIGITAL(pin + 6), (value & 0x40));
  if ((bitmask & 0x80)) digitalWrite(PIN_TO_DIGITAL(pin + 7), (value & 0x80));
  return 1;
#endif
#ifndef TOTAL_PORTS
#define TOTAL_PORTS             ((TOTAL_PINS + 7) / 8)
#endif
#endif /* Firmata_Boards_h */
Temani3
by adafruit_support_mike on Thu Nov 23, 2017 12:43 am
Thank you.
That file does contain a board definition for the Circuit Playground Express (just above the line that triggers the error message), so the compiler isn't recognizing it properly.
Try updating all the board support packages you've added to the Arduino IDE and see if that helps. The values that identify specific boards and microcontrollers have changed in the past couple of releases.
by Temani3 on Thu Nov 23, 2017 4:25 am
I looked into my ‘Manage Library’ tab and didn’t see any updatable libraries. Also, I went into the ‘Additional Board Manager’ under Preferences and found the adafruit package, but no way to update it. Am I not looking in the right place?
Temani3
by adafruit_support_mike on Thu Nov 23, 2017 5:06 pm
You want the Boards Manager under the Tools->Board menu.
by Temani3 on Sun Nov 26, 2017 6:38 am
I checked everything that had to do with the board; AVR, SAMD, etc. they all have the most updated version of themselves.
Temani3
by adafruit_support_mike on Mon Nov 27, 2017 3:00 am
In that case, the boar support file might be corrupted. That can happen sometimes, with older files not being deleted as they should be. It's especially common if you jump a couple of versions when you update.
Try deleting your Arduno15 folder and reinstalling the most recent board support packages from scratch.
by Temani3 on Fri Dec 01, 2017 5:15 am
Excuse the delayed response, Work was odd this week.
That makes sense. I have the Classic (Files & Hardware) as well so, having that most likely messed things up. I am, however, having trouble locating the ‘Arduino15’ you mentioned.
Temani3
by adafruit_support_mike on Fri Dec 01, 2017 5:38 pm
What operating system are you using?
by Temani3 on Tue Dec 05, 2017 1:36 am
I am using Windows 8
Temani3
