Trellis functioning erratically
by crthomas0 on Mon Nov 20, 2017 7:09 pm
Hi, I've assembled, addressed, and wired four trellis boards [PRODUCT ID: 1929] and am seeing erratic behavior when I run the trellis test program from the library. I have several videos to show what is happening, however, they are too larger to attach using this forum. I've also noticed that there is a missing component [I'm guessing that its a cap] on two of the boards, and have attached a picture of each of these locations.
Thanks,
Chris
crthomas0
Re: Trellis functioning erratically
by adafruit_support_mike on Tue Nov 21, 2017 3:03 am
Yes, those would be debouncing capacitors. From the nature of the damage, it looks like they were cracked off mechanically.
There should be one at each edge of the board, and all of them have the same job: absorb any volage spikes on the supply rails. Losing one isn't great, but won't make the board fail instantly.
Could you post a photo showing your overall assembly please?
by crthomas0 on Tue Nov 21, 2017 10:28 am
This is the best photo that I have now of the entire assembly. Let me know if you want to see more and I can get another photo later today.
crthomas0
by crthomas0 on Tue Nov 21, 2017 12:26 pm
Here is a better photo of the entire setup.
crthomas0
by adafruit2 on Tue Nov 21, 2017 12:37 pm
those capacitors wouldn't be causing inconsistant behavior - there's plenty of others.
maybe try the trellis one at a time (e.g. not in a panel?) see if you can narrow down the issue
adafruit2
Site Admin
by crthomas0 on Tue Nov 21, 2017 1:27 pm
The panels are addressed as suggested in the tutorial:
And here is a photo I extracted from the video to show the LED state that occurred during the first test:
As_assembled:
0x70: LED #6 is not functioning
0x72: LED #1 is not functioning
crthomas0
by crthomas0 on Tue Nov 21, 2017 1:29 pm
I re-flowed the two solder joints for 0x70 LED #6 [did not do anything with 0x72 LED #1] and then ran the test again. The following photos are each separate runs of the same trellis test program and show the different LED states:
Reflowed #1.JPG (72.49 KiB) Viewed 342 times
Reflowed #2.JPG (58.79 KiB) Viewed 342 times
Reflowed #3.JPG (53.07 KiB) Viewed 342 times
crthomas0
by crthomas0 on Tue Nov 21, 2017 1:31 pm
[Reflowed Con't]
Reflowed #4.JPG (57.16 KiB) Viewed 342 times
Reflowed #5.JPG (38.91 KiB) Viewed 342 times
Also received this error after the last test:
USB device error.JPG (27.28 KiB) Viewed 342 times
crthomas0
by crthomas0 on Tue Nov 21, 2017 5:59 pm
Any thoughts/suggestions/things to test based on the last set of info/photos before I disassemble the panels to test them individually as suggested by adafruit2?
crthomas0
by zener on Tue Nov 21, 2017 7:40 pm
Some of the LED soldering looks suspect, and that could cause LED's to be out that are supposed to be on. However, I am not sure what other wrong behavior you are getting.
zener
