raspberry pi was working then died
by davemegg on Tue Nov 21, 2017 3:00 pm
hello,
I was using a raspberry pi3 from (ORDER #1589918-6485227214) delivered 11/14/2017 at 9:44 A.M.. It had been running raspian stretch from a micro sd card. Software to run apache2 and a webcam had been installed. I noticed that the plastic enclosure was getting slightly warm and the machine need to be frequently rebooted to run the webserver. Now today it failed to boot. I tried re installing a fresh copy of raspian using a sd card writer "pi baker". Now the power led is off and the pi seems to be completely dead with two different power supplies which work fine with other raspberry pi's.
Thanks for the help.
davemegg
Re: raspberry pi was working then died
by adafruit_support_mike on Wed Nov 22, 2017 12:15 am
What voltages do you see on the 3.3v and 5v pins of the GPIO header?
by davemegg on Wed Nov 22, 2017 10:28 am
1.77 v from the 3.3v and 5.2v from the 5v
dave
davemegg
by adafruit_support_mike on Wed Dec 20, 2017 9:01 pm
Sorry for the delay.
That indicates a failure in the microprocessor. Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will get you a replacement Pi3.
(#3055)
