Small costume project w/powerboost & neo pixel rings
by vegas78 on Wed Nov 22, 2017 12:20 am
Hi I have a costuming project that I would like to use the Neopixel rings on. It only requires white steady light- no blinking or rgb switching etc. Initially I was looking at using the Powerboost 500 with the 3.7 lipo battery, conductive thread, and a push toggle switch such as a clicky switch for flashlight (https://www.aliexpress.com/item/OMTEN-P ... 0.0.O0bovZ.) Will this work on the Neopixel rings directly from the Powerboost? Thanks in advance.
vegas78
Re: Small costume project w/powerboost & neo pixel rings
by adafruit_support_mike on Wed Nov 22, 2017 12:37 am
You can run NeoPixel rings from a PowerBoost, and the switch looks like it would be able to control that power, but you'll also need a microcontroller.
NeoPixels don't do anything on their own. They need a microcontroller to generate the signals that tell them what to do with their LEDs.
What you're doing sounds simple enough that a Gemma should be more than enough to handle the job though:
https://www.adafruit.com/product/1222
by vegas78 on Thu Nov 23, 2017 12:33 pm
Awesome- thanks for the reply. So I had a friend give me one of his gemmas and I've downloaded and installed Arduino IDE and the drivers etc. Could you point me in the right direction for a sketch that would allow the neopixel rings to emit steady white light? I'm totally new to mini controllers, boards, libraries etc. Thanks again!
vegas78
by adafruit_support_mike on Thu Nov 23, 2017 5:18 pm
The best place to start would be the example sketch named ‘simple’ in the NeoPixel library:
https://github.com/adafruit/Adafruit_Ne ... simple.ino
You set the output color of a pixel with the red, green, and blue values in the function .setPixelColor().
