It's 🐍CircuitPython Monday🐍 at Adafruit! Use the code ADATY to get 20% off CircuitPython and 15% off items storewide!
Radiohead example fails with Feather M0 RFM9x
by igeekinc on Wed Nov 22, 2017 2:41 am
I purchased 2 Feather M0 RFM9x boards. I'm trying to get the sample code to work but both of them fail in the RH_RF95 init() call. I have selected the Feather M0 parameters:
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
and these also seem to correspond to the recommended settings for a Feather M0 board from the Radiohead readme that says:
For Adafruit Feather M0 with RFM95, construct the driver like this:
RH_RF95 rf95(8, 3);
Any tips or tricks for making this work? Both boards fail the same way, so I don't think it's a hardware problem. I have connected an antenna to both.
Here's the full code of the example with my modifications
      // Feather9x_TX
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (transmitter)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Feather9x_RX
#include <SPI.h>
#include <RH_RF95.h>
/* for feather32u4 */
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
/* for feather m0  */
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
/* for shield
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 7
/* for ESP w/featherwing
#define RFM95_CS  2    // "E"
#define RFM95_RST 16   // "D"
#define RFM95_INT 15   // "B"
/* Feather 32u4 w/wing */
#define RFM95_RST     11   // "A"
#define RFM95_CS      10   // "B"
#define RFM95_INT     2    // "SDA" (only SDA/SCL/RX/TX have IRQ!)
/* Feather m0 w/wing */
#define RFM95_INT     6    // "D"
/* Teensy 3.x w/wing
#define RFM95_RST     9   // "A"
#define RFM95_INT     4    // "C"
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
void setup()
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  while (!Serial);
  Serial.begin(9600);
  delay(100);
  Serial.println("Feather LoRa TX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    //while (1);
    delay(1000);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
int16_t packetnum = 0;  // packet counter, we increment per xmission
void loop()
  Serial.println("Sending to rf95_server");
  // Send a message to rf95_server
  char radiopacket[20] = "Hello World #      ";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  radiopacket[19] = 0;
  Serial.println("Sending..."); delay(10);
  rf95.send((uint8_t *)radiopacket, 20);
  Serial.println("Waiting for packet to complete..."); delay(10);
  rf95.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  Serial.println("Waiting for reply..."); delay(10);
  if (rf95.waitAvailableTimeout(1000))
    // Should be a reply message for us now
    if (rf95.recv(buf, &len))
      Serial.print("Got reply: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
    else
      Serial.println("Receive failed");
  else
    Serial.println("No reply, is there a listener around?");
  delay(1000);
igeekinc
Re: Radiohead example fails with Feather M0 RFM9x
by adafruit_support_mike on Thu Nov 23, 2017 12:38 am
What are the symptoms of the failure?
by igeekinc on Thu Nov 23, 2017 1:11 pm
rf95.init() returns false. There's no other diagnostics from the Radiohead library that I can see. Is there a way to enable debugging? Am I using the correct parameters for the Feather M0 RFM9x board?
igeekinc
by igeekinc on Mon Nov 27, 2017 12:19 am
This line in setup causes the init to fail
I commented it out and init finishes OK now. I'm going to try to get the two boards to talk next.
igeekinc
by adafruit_support_mike on Mon Nov 27, 2017 4:30 am
Hmm.. that's really unusual.
Try putting that line back and increasing the delay() time after the manual reset in setup().
by rathole on Fri May 10, 2019 10:00 am
Did you ever find a solution to your issue... I have the same problem.
Bluefruit Feather M0
Have most recent github files -> Example -> Radiohead -> Feather -> Feather9x ...
#define RF69_FREQ 915.0
#define RFM69_CS 8
#define RFM69_INT 3
#define RFM69_RST 4
#define LED 13
RH_RF69 rf69(RFM69_CS, RFM69_INT);
fails here on 2 different boards
if (!rf69.init()) {
Serial.println("RFM69 radio init failed");
while (1);
increased delay as mentioned in this post to no avail
rathole
by adafruit_support_mike on Sat May 11, 2019 2:20 am
Does commenting out the line:
make any difference?
by JohnnyBG on Fri May 17, 2019 6:28 pm
rathole wrote:Did you ever find a solution to your issue... I have the same problem.
#define RFM69_CS 8
#define RFM69_INT 3
#define RFM69_RST 4
#define LED 13
if (!rf69.init()) {
while (1);
Exactly the same issue here, bluefruit nRF52 will not init RFM69, just keep stuck indefinitely there, but I see your are using the wrong pins, corresponding to the Feather M0, not the Bluefruit M0
JohnnyBG
by sirjano on Mon Sep 09, 2019 10:22 am
I have exactly same problem with my Adafruit Feather 32u4.
Commenting out
solves init problem, but doesn't it break the code?
My pins defined:
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
sirjano
by pserotta on Mon May 25, 2020 12:53 am
I am seeing the same problem as the original post.
I don't think it is a good idea to comment out the line
as then I suspect the radio is not reset.
I tried various delays as was suggested by Adafruit support but that does not solve the issue.
I don't see a proper solution in this thread, can we please get more assistance with this issue as the 2 feather M0 with RFM9x radios are not working at all for me?
pserotta
by jerryn on Mon May 25, 2020 6:24 am
What library are you using? Have you tried the examples from this guide https://learn.adafruit.com/adafruit-feather-m0-radio-with-lora-radio-module/using-the-rfm-9x-radio?preview_token=IU2C_sI1Vkd78VJQTNxu1w#radiohead-rfm9x-library-example-2567678-4
If you post the code you are trying, I'll be happy to see if I can reproduce you're issue.
Just to be clear, I do not represent Adafruit, Just trying to help.
jerryn
by pserotta on Mon May 25, 2020 10:45 am
Thank you, any help is welcome.
I am using RadioHead 1.62 with the sample application from Adafruit:
Feather9x_TX.zip
Feather9x from Adafruit
(1.99 KiB) Downloaded 3 times
The only modification made was to uncomment the M0 defines.
This is the error:
 Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug
The statement to uncomment the SERIAL_DEBUG define does not match the RH_RF95.cpp file included in RadioHead 1.62 so I suspect the library has changed.
Perhaps version 1.62 no longer works with the sample?
pserotta
by jerryn on Mon May 25, 2020 1:14 pm
I just ran this code -- on a feather M0 RFM9x Lora -- with both Radiohead 1.62 and the latest v 1.02
and it executes normally for me with both versions.
What Board are you selecting? -- I used Adafruit Feather M0
// Feather9x_TX
#include <SPI.h>
/* for feather32u4
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
/* for feather m0
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
/* for shield
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 7
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
void setup()
  Serial.begin(115200);
  while (!Serial) {
    delay(1);
  delay(100);
  // manual reset
  delay(10);
  delay(10);
    Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
    while (1);
    while (1);
void loop()
  delay(1000); // Wait 1 second between transmits, could also 'sleep' here!
  Serial.println("Transmitting..."); // Send a message to rf95_server
  delay(10);
  delay(10);
    else
  else
jerryn
by pserotta on Mon May 25, 2020 7:26 pm
I am also using board: Adafruit Feather M0
When you say: with both Radiohead 1.62 and the latest v 1.02
What do you mean by latest v1.02?
Also, what versions of the board support packages are you running?
I have attached the versions I am using.
Thanks again for helping!
pserotta
by jerryn on Mon May 25, 2020 7:56 pm
Sorry that was a typo .the latest is v1.102. https://www.airspayce.com/mikem/arduino/RadioHead/
I’ll check BSP version when I can get back to my computer but they are recent if not latest.
jerryn
