Black Lives Matter - Action and Equality.
eagle question
eagle question
by geir102 on Wed Sep 23, 2009 7:36 am
Hi
Just sampled the TXS014EDR for ti. Im trying to make a package for it in eagle. Its soic14D and i found the so14 package from another library. But when i print it out the TXS014EDR is a little to big. Am i doing something wrong? soic14=so14 should be a standard size.
geir102
Re: eagle question
by geir102 on Wed Sep 23, 2009 8:44 am
Problem always solves itself after you ask :)
I was converting it to pdf befor printing this resized it so it dident fit :oops:
geir102
Re: eagle question
by westfw on Wed Sep 23, 2009 10:52 am
PDF output from Eagle seems to be filled with peril. Printing output in general is only so-so (better than many packages, but it seems to assume a resolution large enough that fine-pitch SMD package pads bleed together, for example.) On a Mac, it seems to work much better to use the CAM processor to output postscript files, and the standard Mac capabilities to convert and print the .PS files...
westfw
