I am having problems getting the GPIO reassigned. I can change the pins out in retrogame.c but they are not responding when saved and going back into the Emulation Station. I have the RaspberryPi Zero with a 2.4 Adafruit TFT and the GPIO pins i am using are going through the TFT and out the 26pin connector and the built in button locations. I have gone in and changed the retrogame.c file to line up with what i wired in, and it is the same when i go back into it but i get no responses from all of the inputs. left down, start, select and "A" and "B" are working though the laster are picking up their input from the "X" and "Y" inputs.
Any ideas on what i amissing the make the changes so that i can use the GPIO inputs?
GPIO Re-assignment issue Retro PI/GBZ
- Golddeenoh
Re: GPIO Re-assignment issue Retro PI/GBZ
this is how it looks in case anyone wanted to see it.
- reduced20171211_160119.jpg (209.79 KiB) Viewed 213 times
It sounds like your wiring doesn't match the pin assignments in /boot/retrogame.cfg.
Use a multimeter to make sure each GPIO pin on the RasPi is really connected to the button it's supposed to be.
