5 inch screen defective.
by ChewbaccaSaurusRex on Sat Dec 16, 2017 3:27 pm
I received a 5 inch screen part #1680 and upon arrival the screen will not display anything when plugged into it's display driver part #2218. I would like a replacement display.
Here are the images since I can't upload them here due to file size. https://imgur.com/a/SPpWg
ChewbaccaSaurusRex
Re: 5 inch screen defective.
by ZipSnipe on Sun Dec 17, 2017 12:11 am
I had to use a pc monitor first and then was able to load the drivers for my 7 inch and then I was able to use the 7inch.
ZipSnipe
by ChewbaccaSaurusRex on Sun Dec 17, 2017 11:21 am
I don't have it plugged into a raspberry pi or PC I have the display driver plugged into a Roku streaming stick. But the screens backlight won't even turn on.
ChewbaccaSaurusRex
by ZipSnipe on Sun Dec 17, 2017 11:32 am
What are you using to power the lcd screen? It needs 5v 2amps to run(usb)
ZipSnipe
by ChewbaccaSaurusRex on Sun Dec 17, 2017 2:25 pm
I'm using a USB power brick with an output of 5v 3.4Amps max.
ChewbaccaSaurusRex
by adafruit_support_mike on Mon Dec 18, 2017 12:22 am
You might be running into a problem with an HDMI 'protected' video stream.
HDMI has a set of rules that won't allow copy-protected video to play on hardware that doesn't enforce all the copy-protection rules. Our displays don't enforce those rules, so they can't play protected content.
Try connecting the display to a RasPi or other computer and see if you can get any output that way.
by ChewbaccaSaurusRex on Mon Dec 18, 2017 8:40 am
I connected it to a raspberry pi zero and the result was the same , I'll try my main computer next.
ChewbaccaSaurusRex
by ChewbaccaSaurusRex on Tue Dec 19, 2017 4:21 pm
adafruit_support_mike wrote:You might be running into a problem with an HDMI 'protected' video stream.
I tried multiple HDMI devices now the display still won't power on.
ChewbaccaSaurusRex
by adafruit_support_mike on Wed Dec 20, 2017 12:57 am
Okay, let's try another display.
Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will get you another display, and may arrange return shipping for the one you have now.
