Hey Braintrust,
I just received my DS18B20 temp sensor, wired it up per any and all instructions, and when I plug it in to either of my PI 3's , the sensor gets
skin burning hot. I show a 4v drop across the resistor. I have checked and double checked all my wiring and it is identical to what is online.
One PI is running Raspbian and the other is running Ubuntu.
Any thoughts?
Rick
DS18B20 Waterproof SensorHot to Touch
Re: DS18B20 Waterproof SensorHot to Touch
Please post a photo showing your connections between sensor and Pi.
- dogs_rule
Here is the breadboard. The blue is to ground.
- 20180116_113028.jpg (89.55 KiB) Viewed 223 times
That looks correct. Sounds like maybe an internal short in the sensor itself. Please contact [email protected] with a link to this thread and we can send a replacement.
- dogs_rule
Thank you!
- adafruit2
also fyi, if you keep having this issue, check that the cable is plugged in right into the Pi - one can get it backwards!
- dogs_rule
Checked. Pin 1 to pin 1.
