franklin97355 wrote:Do you have the spreadsheet set up in Google and can you log in and read/write to it? Can you post the code you are trying to run? Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
spreadsheet is setup and can be read/wrote to
the code is the one that is included in the adafruit download
also the json file that i downloaded via the google developers console looks ok
#!/usr/bin/python
# Google Spreadsheet DHT Sensor Data-logging Example
# Depends on the 'gspread' and 'oauth2client' package being installed. If you
# have pip installed execute:
# sudo pip install gspread oauth2client
# Also it's _very important_ on the Raspberry Pi to install the python-openssl
# package because the version of Python is a bit old and can fail with Google's
# new OAuth2 based authentication. Run the following command to install the
# the package:
# sudo apt-get update
# sudo apt-get install python-openssl
# Copyright (c) 2014 Adafruit Industries
# Author: Tony DiCola
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import json
import sys
import time
import datetime
import Adafruit_DHT
import gspread
from oauth2client.service_account import ServiceAccountCredentials
# Type of sensor, can be Adafruit_DHT.DHT11, Adafruit_DHT.DHT22, or Adafruit_DHT.AM2302.
DHT_TYPE = Adafruit_DHT.DHT11
# Example of sensor connected to Raspberry Pi pin 23
DHT_PIN = 4
# Example of sensor connected to Beaglebone Black pin P8_11
#DHT_PIN = 'P8_11'
# Google Docs OAuth credential JSON file. Note that the process for authenticating
# with Google docs has changed as of ~April 2015. You _must_ use OAuth2 to log
# in and authenticate with the gspread library. Unfortunately this process is much
# more complicated than the old process. You _must_ carefully follow the steps on
# this page to create a new OAuth service in your Google developer console:
# http://gspread.readthedocs.org/en/latest/oauth2.html
# Once you've followed the steps above you should have downloaded a .json file with
# your OAuth2 credentials. This file has a name like SpreadsheetData-<gibberish>.json.
# Place that file in the same directory as this python script.
# Now one last _very important_ step before updating the spreadsheet will work.
# Go to your spreadsheet in Google Spreadsheet and share it to the email address
# inside the 'client_email' setting in the SpreadsheetData-*.json file. For example
# if the client_email setting inside the .json file has an email address like:
# 149345334675-md0qff5f0kib41meu20f7d1habos3qcu@developer.gserviceaccount.com
# Then use the File -> Share... command in the spreadsheet to share it with read
# and write acess to the email address above. If you don't do this step then the
# updates to the sheet will fail!
GDOCS_OAUTH_JSON = 'humidity.json'
# Google Docs spreadsheet name.
GDOCS_SPREADSHEET_NAME = 'callumtest'
# How long to wait (in seconds) between measurements.
FREQUENCY_SECONDS = 30
def login_open_sheet(oauth_key_file, spreadsheet):
"""Connect to Google Docs spreadsheet and return the first worksheet."""
try:
scope = ['https://spreadsheets.google.com/feeds']
credentials = ServiceAccountCredentials.from_json_keyfile_name(oauth_key_file, scope)
gc = gspread.authorize(credentials)
worksheet = gc.open(spreadsheet).sheet1
return worksheet
except Exception as ex:
print('Unable to login and get spreadsheet. Check OAuth credentials, spreadsheet name, and make sure spreadsheet is shared to the client_email address in the OAuth .json file!')
print('Google sheet login failed with error:', ex)
sys.exit(1)
print('Logging sensor measurements to {0} every {1} seconds.'.format(GDOCS_SPREADSHEET_NAME, FREQUENCY_SECONDS))
print('Press Ctrl-C to quit.')
worksheet = None
while True:
# Login if necessary.
if worksheet is None:
worksheet = login_open_sheet(GDOCS_OAUTH_JSON, GDOCS_SPREADSHEET_NAME)
# Attempt to get sensor reading.
humidity, temp = Adafruit_DHT.read(DHT_TYPE, DHT_PIN)
# Skip to the next reading if a valid measurement couldn't be taken.
# This might happen if the CPU is under a lot of load and the sensor
# can't be reliably read (timing is critical to read the sensor).
if humidity is None or temp is None:
time.sleep(2)
continue
print('Temperature: {0:0.1f} C'.format(temp))
print('Humidity: {0:0.1f} %'.format(humidity))
# Append the data in the spreadsheet, including a timestamp
try:
worksheet.append_row((datetime.datetime.now(), temp, humidity))
except:
# Error appending data, most likely because credentials are stale.
# Null out the worksheet so a login is performed at the top of the loop.
print('Append error, logging in again')
worksheet = None
time.sleep(FREQUENCY_SECONDS)
continue
# Wait 30 seconds before continuing
print('Wrote a row to {0}'.format(GDOCS_SPREADSHEET_NAME))
