MAX31865 Breakout board giving random numbers
Re: MAX31865 Breakout board giving random numbers
by adafruit2 on Sat Feb 24, 2018 3:52 pm
ahhh! found the bug! try version 1.0.1 of the library, just pushed it
adafruit2
Site Admin
by mhxsol on Mon Feb 26, 2018 5:09 pm
Yes, problem solved.
Output is now:
RTD value: 7509
Ratio = 0.22915649
Resistance = 985.37292480
Temperature = -3.74
Great work, top service.
mhxsol
by kaushik18790 on Wed Mar 21, 2018 3:36 am
Dear Sir/Madam
I am also getting random values and they are keep on changing.
kaushik18790
by adafruit_support_bill on Wed Mar 21, 2018 7:00 am
@kaushik18790 - Are you using version 1.0.1 of the library? It was just updated recently. https://github.com/adafruit/Adafruit_MAX31865
by paemail on Thu Mar 29, 2018 11:09 am
Dear Sir / Madam,
I am also getting random values with a Kemo DIN/EN60751 Class "B" Pt-100 RTD (3 wire) and max31865 on Adruino UNO (IDE 1.8.5). I've installed library version 1.0.1 but still have the problem.
Here is the code (Adafruit example):
#include <Adafruit_MAX31865.h>
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 max = Adafruit_MAX31865(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31865 max = Adafruit_MAX31865(10);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF      430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL  100.0
  Serial.begin(115200);
  Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
  max.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
  uint16_t rtd = max.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd);
  float ratio = rtd;
  ratio /= 32768;
  Serial.print("Ratio = "); Serial.println(ratio,8);
  Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
  Serial.print("Temperature = "); Serial.println(max.temperature(RNOMINAL, RREF));
  // Check and print any faults
  uint8_t fault = max.readFault();
  if (fault) {
    Serial.print("Fault 0x"); Serial.println(fault, HEX);
    if (fault & MAX31865_FAULT_HIGHTHRESH) {
      Serial.println("RTD High Threshold");
    if (fault & MAX31865_FAULT_LOWTHRESH) {
      Serial.println("RTD Low Threshold");
    if (fault & MAX31865_FAULT_REFINLOW) {
      Serial.println("REFIN- > 0.85 x Bias");
    if (fault & MAX31865_FAULT_REFINHIGH) {
      Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_RTDINLOW) {
      Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_OVUV) {
      Serial.println("Under/Over voltage");
    max.clearFault();
  Serial.println();
  delay(10000);
And here is my setup:
Any help is appreciated
Thank you in advance.
paemail
by adafruit2 on Thu Mar 29, 2018 11:12 am
follow the guide for 3-wire operation, you need to adjust the jumpers
adafruit2
Site Admin
by adafruit_support_bill on Thu Mar 29, 2018 11:17 am
If you are using a 3-wire probe, you need to set the 3-wire jumper as described here: https://learn.adafruit.com/adafruit-max ... re-sensors
by Delivery2you on Tue Sep 18, 2018 8:10 am
I have also issues with PT1000. It seems on your example you have some kind of capacitor between the 5V and GRN. It is not described anywhere in the wiring diagram.
I am using 5V exit pin on the Nano and when I put the code on, the voltage drops to 3.8 and below, from the initial reading of around 4.6V.
Delivery2you
by adafruit2 on Tue Sep 18, 2018 12:45 pm
please use a breadboard, you aren't getting any data, something is amiss with your wiring
adafruit2
Site Admin
by Delivery2you on Tue Sep 18, 2018 1:10 pm
So, it seems, and now the code is giving me a different error. Which btw I got from the testing before.
Delivery2you
by adafruit2 on Tue Sep 18, 2018 1:19 pm
hiya - that product isnt from us its a clone - please contact the vendor for support :)
adafruit2
Site Admin
