Pigrrl 2 Screen Problem
- Heidi42
I've been working on the Pigrrl 2 project (I ordered the kit) and have everything soldered now. I tried testing everything before but it in the case but ran into a problem. Nothing shows on the screen and it makes a screeching sound from the speaker. I reloaded the sd card to make sure the files weren't a problem and started desoldered components to narrow down the problem. It seems to be in the screen because the Pi and battery board light up properly until the screen is plugged in, then the blue battery light turns off and the charging board gets hot. I tried testing the screen with the Pi by itself plugged into usb power and the Pi shows it has power but the screen does nothing. I disconnected the trace for the backlight as was suggested in the guide but put a temporary solder bridge back on for testing. So far it still seems to do nothing, not even a backlight. Is there anything else I should try or is the screen just dead for some reason? I've checked my soldering and everything seems to work up until the screen.
Re: Pigrrl 2 Screen Problem
- Heidi42
Nevermind, I have it fixed now. A transistor wasn't working but it is replaced now. After the transistor was replaced everything started working.
Glad to hear you got it working. Happy hacking!
