This is a library for the Adafruit PT100/P1000 RTD Sensor w/MAX31865
Designed specifically to work with the Adafruit RTD Sensor
----> https://www.adafruit.com/products/3328
This sensor uses SPI to communicate, 4 pins are required to
interface
products from Adafruit!
BSD license, all text above must be included in any redistribution
#include <Adafruit_MAX31865.h>
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 max = Adafruit_MAX31865(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31865 max = Adafruit_MAX31865(10);
// The value of the Rref resistor. Use 430.0!
#define RREF 430.0
Serial.begin(115200);
Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
max.begin(MAX31865_3WIRE); // set to 2WIRE or 4WIRE as necessary
uint16_t rtd = max.readRTD();
Serial.print("RTD value: "); Serial.println(rtd);
float ratio = rtd;
ratio /= 32768;
Serial.print("Ratio = "); Serial.println(ratio,8);
Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
Serial.print("Temperature = "); Serial.println(max.temperature(100, RREF));
// Check and print any faults
uint8_t fault = max.readFault();
if (fault) {
Serial.print("Fault 0x"); Serial.println(fault, HEX);
if (fault & MAX31865_FAULT_HIGHTHRESH) {
Serial.println("RTD High Threshold");
if (fault & MAX31865_FAULT_LOWTHRESH) {
Serial.println("RTD Low Threshold");
if (fault & MAX31865_FAULT_REFINLOW) {
Serial.println("REFIN- > 0.85 x Bias");
if (fault & MAX31865_FAULT_REFINHIGH) {
Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_RTDINLOW) {
Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_OVUV) {
Serial.println("Under/Over voltage");
max.clearFault();
Serial.println();
delay(1000);
I am unable to get any readings from the amplifier, with an RTD value of zero. This does not change whether the PT 100 is plugged in or not, and I am not getting any error messages, simply no reading.
I have double check all soldering points for good connections, replaced all wires, used different breadboards, tested resistance on 24 3 trace cut to verify that cut is good, used several different amplifiers, verified that the PT100 was reading the correct resistance for room temp, and tried both 5v and 3.3v.
I had proper readings before but struggled when adding more amplifiers and temperature sensors to the circuit, but now nothing works.
Any help would be greatly appreciated, been trying to troubleshoot this for 2+ weeks with little success.
