computer adjustable power source
- rdieter
I need a chip, or chip set, that can deliver computer adjustable output power from a 225 volt source. It must be able to deliver from about 50 volts to about 200 volts. I need to be able to control this output via parallel port or I2C or the like. the output current will be fairly low. Any suggestions as to what might work?
- adafruit_support_mike
Re: computer adjustable power source
We don't carry anything that works in that voltage range, and I don't know of any high-voltage bench supplies that would fit the bill. Most standard transistors only work up to about 60V, and high-voltage transistors usually stop around 150V. It takes specialized components and techniques to work at higher voltages.
Your best bet would be to check with a university physics department and see what suggestions they have. They do a lot of high-voltage work, and will have a better idea of what's available.
