LED Matrix Sand Toy
kpyogendran
LED Matrix Sand Toy
Post by kpyogendran »
Hi Team - have been recreating the Project https://learn.adafruit.com/matrix-led-sand?view=all
LED Matrix Sand toy.
have got all the Parts from Adafruit
64x64 is working fine with RGB matrix bonnet
however i have connected LIS3DH and Powerboost when i try to run program sudo python buttons.py it does not work with Acceleration or doesnt lit up the LEDS.
its lighting up one portion only.
what is wrong in my setup ?
adafruit_support_mike
Re: LED Matrix Sand Toy
kpyogendran
back
back
IMG_1216 2.jpg (924.02 KiB) Viewed 421 times
Front
Front
IMG_1217 2.jpg (955.44 KiB) Viewed 421 times
kpyogendran
i didnt solder the Reset Button and Mode button yet.
Just tried to run sudo python buttons.py from ssh connection
Try working through the installation instructions for the Matrix Bonnet without any of the code from the sand toy project:
https://learn.adafruit.com/adafruit-rgb ... g-matrices
There are some known issues between the LED Matrix driver code and a RasPi's overclocking speed. That tutorial explains how to deal with them.
kpyogendran
These modules of RPI RGB LED matrix were working fine.
after Soldering the button's on Pin 19 and 25 i do see the display is not good.
Also i do seee this message
FYI: Couldn't set affinity: Invalid argument
Size: 64x64. Hardware gpio mapping: adafruit-hat
IMG_1218 2.jpg (819.57 KiB) Viewed 392 times
kpyogendran
Reset and mode buttons are soldered on Bonnet Hat 9 and 25 respectively.
and Ground is connected to the Ground port of Power boost along with SPDT switch ground.
Snow demo is working as expected however when i press the either of the buttons - reset or mode changes doesnt work .
pi@raspberrypi:~/Projects/LED-Sand/Adafruit_PixelDust/raspberry_pi $ sudo ./demo1-snow
kpyogendran
Hello any suggestions?
Let me check with the developer for that project. If the matrix works normally for the example sketches, we can probably rule out a hardware problem.
pburgess
Post by pburgess »
Is the 'E' solder bridge set to pin 8 on the back of the Matrix Bonnet board?
kpyogendran
Yes its. LED matrix 64 x 64 is connected and working as well.
only the Push buttons arent working ...
pburgess
Post by pburgess »
Oh! Misunderstood the issue. I get it now.
The button handling isn't processed by the demo programs themselves (demo1-snow, etc.). Instead, there's a Python wrapper program that reads the buttons and switches among the three demos:
kpyogendran
Yes i do understand that and i have added the python wrapper program into /etc/init.d to load during the startup as well.
even when i tried to run sudo python button.py after than both buttons never respond for changing mode or reset.
by default snow flakes effect is working when i issue the python wrapper command..
pburgess
Post by pburgess »
Can I see more of the back-side wiring? It's not clear where the buttons are connected.
The guide does show the GND connections from the buttons going to one pin of the switch...which, technically, should work, but conceptually is a bit roundabout, and might make more sense to split off from the ground connection on the bonnet.
kpyogendran
Ground for both the buttons connected with SPDT switch Ground and soldered on Ground Pin of Power boost.
its not clear in the Guide video however i have followed the circuit diagram provided in the guide.
https://learn.adafruit.com/matrix-led-s ... it-diagram
