Dear Adafruit-Team,
is it possible to use the "Adafruit DC & Stepper Motor HAT for Raspberry Pi - Mini Kit" with the Raspberry Pi 3? And where can I get the libary for the shield?
Luca
- Nickname00
Re: Adafruit DC & Stepper Motor HAT for Raspberry Pi - Mini
The HAT will work with the Pi-3. Links to the library can be found in the guide: https://learn.adafruit.com/adafruit-dc- ... i?view=all
- Nickname00
Thank you for the fast reply! Another question...is it also possible to use analog sensors without any extras?
The Pi has no native analog inputs. You would need an ADC of some sort:
https://www.adafruit.com/product/1085
https://www.adafruit.com/product/1083
https://www.adafruit.com/product/3194
https://www.adafruit.com/product/3289
https://www.adafruit.com/product/856
- Danzxzx
I have used these in a number of applications and they are fantastic but on my current project I am operating at the upper limit of the allowable current and have fried one of the channels.
Is it possible to "amplify" the signal to allow larger motors that draw more than 1.5A to be controlled using this HAT?
Thanks in advnace
Thanks in advnace
To run larger motors with higher current requirements, you need a beefier motor driver. We have the DRV8871:
https://www.adafruit.com/product/3190
If you are driving steppers, you can combine two of them for that:
https://learn.adafruit.com/current-limi ... 1/overview
Also check with www.pololu.com for a wide selection of higher current motor drivers for both DC motors and steppers.
- Danzxzx
Thanks Bill
The motors I'm using pull around 5A so the Polou boards would have been perfect but I've got all the code written out in python and using the pi for other things in the project.
Would be possible to use the motor HAT to control a couple of beefier MOSFETS https://docs-emea.rs-online.com/webdocs ... 3c07c8.pdf similar to the ones used on the polou boards?
What type of motors are they? If you are driving bipolar steppers or DC motors and need direction control, just MOSFETs are not sufficient. You really need some H-bridges so that you can reverse the current flow.
- Danzxzx
They are DC brushed wiper motors and I do need to change direction but I could potentially use a separate channel for each direction so say:
M1 forward motor 1
M2 backwards motor 1
M3 forward motor 2
M4 forward motor 2
Or would a H bridge be a better solution?
M1 forward motor 1
M3 forward motor 2
M4 forward motor 2
Connecting two MOSFETs to control the same motor in different directions is a recipe for smoke. You really need something like an H-bridge to reverse direction. Pololu has a good selection of DC motor drivers.
One option that may be able to make use of the code you already have is to use a Servo HAT to control the motor drivers.
Our Motor HAT consists of a pair of TB6612 motor drivers controlled by a PCA9685 PWM generator chip.
The Servo HAT is just a PCA9685 PWM generator chip. You would effectively replace the TB6612 drivers on the motor shield with some more powerful drivers such as the ones from Pololu.
- Nickname00
Dear Adafruit-Team,
I installed the library how you said...but unfortunately it doesn't work. I just started the example program and get this failure: I hope you can help me.
File "/home/pi/Adafruit-Motor-HAT-Python-Library/examples/DCTest.py", line 2, in <module>
from Adafruit_MotorHAT import Adafruit_MotorHAT, Adafruit_DCMotor
ImportError: No module named 'Adafruit_MotorHAT'
The error message says "No module named 'Adafruit_MotorHAT'", so it is not finding the motor hat library.
Try re-installing according to the instructions here:
https://learn.adafruit.com/adafruit-dc- ... g-software
- Nickname00
Thank you for the fast reply but it doesn't work already. Is there an other way to import the HAT Library?
I will check with some of our Raspberry Pi experts.
- adafruit2
nick, whats the output of
"sudo python setup.py install"?
