- -Windows 7 64-bit on a fairly new machine
-python 2.7
-Eagle 9.0.0
-no spaces in any names in the path to the "FritzingTest" WORKING directory
-no spaces in any names in the path to Eagle 9.0.0
-I have a "brds" directory within the "FritzingTest" working directory, and I have a .brd file in the "brds" directory
-I am running the Adafruit pre-compiled brd2svg.exe in a command prompt that I opened as an administrator, and that works just fine (the output looks identical to that in the Guide)
-I updated the run.py and run.sh scripts using Notepad++ to point to Eagle and the Working directory, and have attached both to this post for review(relabeled as .txt files so they will upload)
C:\Users\Office\Documents\Fritzing\Eagle2Fritzing\eagle2fritzing\brd2svg>python run.py
['FritzingTest/brds\\RAMPS14.brd']
win32
File "preprocess.py", line 37, in <module>
dom = parse(sys.argv[1]) # infile
File "C:\Python27\lib\xml\dom\minidom.py", line 1918, in parse
return expatbuilder.parse(file)
File "C:\Python27\lib\xml\dom\expatbuilder.py", line 924, in parse
result = builder.parseFile(fp)
File "C:\Python27\lib\xml\dom\expatbuilder.py", line 207, in parseFile
parser.Parse(buffer, 0)
xml.parsers.expat.ExpatError: not well-formed (invalid token): line 1, column 0
File "run.py", line 49, in <module>
NEWSIZE = os.stat(FILENAME+".tmp")[6]
WindowsError: [Error 2] The system cannot find the file specified: 'FritzingTest/brds\\RAMPS14.brd.tmp'
Thanks in advance...Sean
