Hi all!
My GUVA-S12SD UV light breakout sensors (Link to product: https://www.adafruit.com/product/1918) seem to respond to stimuli quite OK. However, in some instances, it seems that when there is no input some of them will still show relatively high values (e.g. most show 0 and some show values >20). Is there a way to calibrate them to some sort of baseline?
All help will be very much appreciated!
Many thanks, Nathalie
GUVA S12SD Calibration
- adafruit_support_bill
Re: GUVA S12SD Calibration
So some of the sensors show high output values even if you cover the sensor? Please post a photo showing your soldering and connections to the problem sensor(s).it seems that when there is no input some of them will still show relatively high values (e.g. most show 0 and some show values >20).
How many sensors total do you have? Do most of them show reasonably consistent values?
- nathalie_
Dear Bill, thank you for getting back to me so quickly!
I have attached a picture of the sensor in this example. The soldering doesn't look too bad. There are eight sensors at the moment, and they usually show 0 (just like in the picture) however on different moments, I might have an aberrant one (in this case the second from the left). Today it was two instead of 0, but sometimes the value can go up to 100 as you can see in one of the screenshots (while the rest show 0).
After taking those pictures, I switched the sensor positions to see what happens and they all went down to 0, but in the future, when the circuit is soldered on a PCB I won't be able to do that. Do you have any recommendations for getting them all to baseline? Or, do you think I might be dealing with a hardware/circuit issue?
Once again, thank you very much for your help,
All the Best,
Nathalie
All the Best,
Nathalie
- Attachments
- Exposed to Light
- sun exposure.PNG (14.53 KiB) Viewed 241 times
- Sensor Close-up
- soldering.PNG (52.93 KiB) Viewed 241 times
- Before exposure
- no exposure.PNG (13.89 KiB) Viewed 241 times
We did have a batch of mismarked parts a while ago. But the symptom there was high readings all of the time.There are eight sensors at the moment, and they usually show 0 (just like in the picture) however on different moments, I might have an aberrant one (in this case the second from the left).
So you currently are using these on a breadboard? Based on the intermittent nature of the problem, I would suspect that you have a marginal connection somewhere. From what I can see in the photo, the soldering looks OK. But jumper wires and breadboard connections can be unreliable.After taking those pictures, I switched the sensor positions to see what happens and they all went down to 0, but in the future, when the circuit is soldered on a PCB I won't be able to do that.
The next time you see abnormal readings, try re-wiring just the offending sensor with a different set of jumper wires. Make sure that they are all firmly gripped by the contacts in the breadboard. If that does not fix the problem, let us know and we can investigate further.
- nathalie_
Sounds like a plan!
Thank you once again for your help!
Nathalie
Nathalie
