DC Stepper Motor IO pins from Raspberry PI 3
Mdplastic
Post by Mdplastic »
We want to run a 24V DC 2.8A Stepper motor using a Oriental Driver CVD245BR-K using the PI. Has anyone been successful running a higher voltage motor and a dedicated driver? Also, what IO's on the PI are used to communicate the PWM code to the driver?
adafruit_support_mike
Re: DC Stepper Motor IO pins from Raspberry PI 3
I'm afraid we don't know anything about that driver. Your best bet will be to contact the manufacturer and see if they have any suggestions about running it from a 3.3V control source.
The RasPi doesn't do PWM very well because of the way Linux handles multitasking. You get better results handing the PWM generation off to a separate device like a PCA9685:
https://www.adafruit.com/product/2327
tech_tach_toe
Post by tech_tach_toe »
Hello.
I have the same Problem wanting to control a CVD245BR-K by Raspberry Pi.
The manual says that only a pulse (NOT PWM) with 5V is needed to control the Driver.
So if my Stepper Motor has 200 steps for 1 complete rotation and I want to have 500 rpm i would need to produce a singal with 1.667 pulses / second.
Does anybody have an idea how to generate such a signal dirctly via Raspberry PI?
Andy suggestions?
I already found the Pulse Train HAT pthat.com but unfortunately it is not available at the moment.
Best regards
tech_tach_toe
A few decimal places off there: 500 RPM with a 200 step motor is 500 * 200 / 60 = 1666.67 pulses / second
A couple issues : The Pi is a 3.3v processor, so the GPIO signal level is also 3.3v. However there are level shifters that can be used to increase the signal voltage. https://www.adafruit.com/product/1875
The other issue is the nature of Linux multitasking as Mike mentioned above. Without getting into kernel-level coding, it is not possible to guarantee sub-millisecond level pulse timing precision as is needed here.
There are a couple of options: One is to use something like a PCA9685 to generate your pulses. This would be OK for continuous rotation, but you would not have control over the exact step count.
A better option would be to offload the pulse generation to a microcontroller better suited to time-critical tasks. The Itsy Bitsy 5v would be a good choice: https://www.adafruit.com/product/3677
