Hi all,
I Wonder where i can buy the tuch screen without all the PCB that sell Adafruit?
When I click on the link that they give :https://cdn-shop.adafruit.com/datasheets/MI0283QT-11+V1.1.PDF, I can't say if this screen has the "capacitiv tuch" inside?
the connector and the design of the cable isn't the same as the one they put on there https://www.adafruit.com/product/2423.
Does Adafruit change the screen by adding the tuching part?
I hope i'm clear.
Best regards
Romain Delacrétaz
TFT tuch screen 2.8" capacitv
Re: TFT tuch screen 2.8" capacitv
We don't sell the capacitive version by itself, but we do have the resistive version:
https://www.adafruit.com/product/1774
Both the resistive and capacitive touchscreen encoders are separate devices, but they're bonded to the surface of the TFT at the factory.
- Skad
Thank you for your reply.
So as I understand the https://www.adafruit.com/product/1774,
Is the same for the capacitiv and resistiv screen.
You add, at the "factory of the screen" some hardware to then provide a capacitiv ou resistiv screen.
Is it right?
if yes, if i buy the https://www.adafruit.com/product/1774, will i be able to manage the tuching part?
If you agree, I'll try to explain my objectif.
I would like to take the https://learn.adafruit.com/adafruit-pit ... /downloads, to
modifiy the PCB to kick out the capacitiv part and replace the pin header by a flat-cable-connector.
So if i let all the connection and just change some "vias", will it work with the screen https://www.adafruit.com/product/1774, or do you add some change on it before put it on your board?
i hope i've made myself clear enough
Best regards
R.D.
Is it right?
Best regards
R.D.
PID 1774 will work with the PiTFT PCB layout.
- Skad
Ok thank you.
Ok thank you.
