Hello
I'm doing the https://learn.adafruit.com/cloud-cam-co ... a/overview and when I get to the Dropbox Uploader setup section I use the git command "git clone https://github.com/andreafabrizi/Dropbox-Uploader.git" and now I get a fatal error message: Directory already exists and is not empty. When I try to run dropbox_uploader I get an error message "Command not recognized"
What should I do?
Thank you for any help
Cloud cam security camera raspberry pi
Re: Cloud cam security camera raspberry pi
Could you post the exact error message you're getting please?
- adasal
Here are the messages
sudo apt-get update
sudo apt-get install -y curl
cd ~
cd Dropbox-Uploader
chmod a+x dropbox_uploader.sh
sudo cp dropbox_uploader.sh /usr/local/bin/dropbox_uploader
fatal: destination path 'Dropbox-Uploader' already exists and is not an empty directory.
pi@raspberrypi:~ $ cd Dropbox-Uploader
pi@raspberrypi:~/Dropbox-Uploader $
pi@raspberrypi:~ $ cd Dropbox-Uploader dropbox_uploader
bash: dropbox_uploader: command not found
sudo apt-get update
cd ~
cd Dropbox-Uploader
Hrm..
Are you entering each of these commands one by one, or pasting the whole set to the command line at once:
sudo apt-get update
cd ~
cd Dropbox-Uploader
- adasal
Actually I am pasting all to the command line. I am new at this so if I enter each command I would probably make an error. Why would pasting all the commands at once not work?
Thank you
Thank you
It looks like the command line thinks it's all one statement, and parts of different commands are getting mixed together.
Entering them one line at a time is safe. It's the preferred way, in fact.
